rear bumper removal
Old Aug 11, 2007 | 09:09 AM
thedudefromjerz's Avatar
Default rear bumper removal
hey guys im having trouble removing the rear bumper off my 90 dx hatch. I removed the two screws in each wheel. Can someone explain where the other screws are to remove the bumper? thanks alot.
Old Aug 11, 2007 | 09:56 AM
IP RACING's Avatar
Default Re: rear bumper removal (thedudefromjerz)
if its the same for sedans and hatches there ones bolt under the on the edge, the side opposite opposite of the exhaust tip. theres a screw under your license plate. and theres alos 1 screw under the tail lights under the little metal trim pieces on each side/ i hink thats it.
Old Aug 11, 2007 | 10:05 AM
ef9robert's Avatar
i think it is best to take the beam off with the bumper attached to it. then take the bumper off the beam frame. You can do this by removing 4 bolts 2 are in side the hatch around the rear tail light i think they are 12 or 14mm don't recall and the other two are located on the bottom of the chassis close to the exaust on side and the other behind the bumper. Good luck.
SeraphimKidd
Jan 1, 2013 01:46 PM
Big red89
10
Jul 2, 2008 09:32 AM
EvenStar
Dec 28, 2006 06:34 PM
SupraRXZ
14
Nov 29, 2006 10:30 AM
eda6
Feb 23, 2006 05:30 PM
