running rich... on a C5... what now?
Old Aug 11, 2007 | 06:39 AM
rewerbcrx's Avatar
Default running rich... on a C5... what now?
i have a p61 chipped ecu, "custom burn" zero daze chip from previous owner.
i want to make it right, would tunning do this, or would placing a stock chip back be a fast reliable fix? the previous guy ran a VAFC and leaned it out BUT i do not know how to use/setup/work a VAFC so i do not wanna mess up my engine....
I know that tunning is my best bet, but to get a tune i have to travel over 4 hours (closest dyno/ tunning)
still learning.......
so whats my next step?
setup
2001 b18c5 w/ obd0 injectors (stock) need at least 388 i know
obd1 dizzy
itr cams
ctr os pistons (12.6:1 cr)
bored .25 over
Vortech fuel rail and FPR
skunk2 IM
Outlaw Engineering intake spacer and TB spacer
OE 4 wire o2 sensor
j1 trans
(i am sure some are familiar with this list)
Modified by rewerbcrx at 11:34 AM 8/11/2007
Old Aug 11, 2007 | 08:07 AM
Mr. Giggles's Avatar
Default Re: running rich... on a C5... what now? (rewerbcrx)
-How rich are you running??
-Not much harm will be done to your motor by running rich, the only thing you might notice is the soot residue built up in your exhaust and when you floor it, a puff of black smoke will come out..
-Getting it properly tuned should help you determine why you are running too rich, and probably solve your issue
Old Aug 12, 2007 | 11:39 AM
rewerbcrx's Avatar
Default Re: running rich... on a C5... what now? (SmrCRX)
thanks... i just figured i already knew what i actually should do but i wanted to throw the question out there
Old Aug 12, 2007 | 05:27 PM
2slow4stock's Avatar
running it wayy to rich is washing out the rings... leaning makes it go BOOM. :D
rewerbcrx
Aug 13, 2007 12:04 PM
gigantor
Nov 11, 2003 07:59 PM
rbf351
Jul 18, 2002 12:00 AM
dbman96
Feb 24, 2002 09:02 AM
schwett
Nov 10, 2001 03:34 AM
