brake problems
Old Jun 12, 2002 | 08:39 AM
badnan's Avatar
Default brake problems
well recently i messed up my rear right suspension, so i went to teh junkyard got the parts and replaced em and now no more suspension problem.
however whnever i accelerate the brake light comes on, and the brakes seem a bit weaker. like when i put my foot on it, it doesnt have as much pressure, the pedal is easier to press.
im guessing it has something to do with the fact that i had to remove the brake caliper and disconect the brake lines to get the parts on.
any ideas why the light comes on and why the brake feels a bit wussy now?
Old Jun 12, 2002 | 09:25 AM
ITC Racer's Avatar
Default Re: brake problems (badnan)
Did you bleed the brakes after opening the lines? If not, this will help. Make sure to bleed all corners and not just the one you replaced.
Old Jun 12, 2002 | 10:27 AM
badnan's Avatar
Default Re: brake problems (ITC Racer)
havent bled the lines, but im thinking that will only make the brakes stronger, not take care of the brake light problem
any one know how to fix that
thanx for the suggestion bout bleeding the lines, dont know why i forgot to do that
Old Jun 12, 2002 | 11:23 AM
Perfectionist's Avatar
Typically, when you bleed the brake system, you will have to replace the fluid that drains out. That will also take care of your "brake light problem".
Old Jun 12, 2002 | 11:24 AM
badnan's Avatar
Default Re: brake problems (Perfectionist)
sweet.
thanks for your help.
Hondaddik
Dec 18, 2012 04:41 PM
donniebrasco
Oct 5, 2004 07:43 AM
Tench
May 11, 2004 10:23 AM
viperguy
Jul 29, 2003 06:57 PM
94BlackRS
Nov 28, 2002 02:43 PM
