It's amazing what....
Sand paper and ugly brown paste can do.
When I got my car, the headlights were clouded over.
My dad told me the film was on the inside. It looked like this
So I bought some 600, 1500, and 2000 grit wetsand sandpaper. I also bought a tub of Turtle wax rubbing compound (not polishing). The whole thing cost me $12, and 5 hours.
After:
After:
the whole headlight is plastic. if you use sand paper like the op, you get rid of the heavy discolored parts but make the whole headlight have a slight cloudyness to it because of the sand paper. and it takes even longer to try to buff them out.
if you use a high speed buffer and a polishing compound, no sand paper, you get rid of of the oxidation and have it crystal clear, close to new. only reason i can say this works better is because i've tried both. and this method works best.
if i still had a headlight available to me to do a "how to" i would. to help everyone out. but i think i remember seeing a thread where someone did it with a white EP3?
but
to the op for posting this and doing a good job.
but
to the op for posting this and doing a good job.Honda-Tech Member
To anyone wanting to do this, there is actually a write-up for it right here:
https://honda-tech.com/zerothread?id=1523524
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Xtream_V »</TD></TR><TR><TD CLASS="quote">if you use a high speed buffer and a polishing compound, no sand paper, you get rid of of the oxidation and have it crystal clear, close to new. only reason i can say this works better is because i've tried both. and this method works best.</TD></TR></TABLE>
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Xtream_V »</TD></TR><TR><TD CLASS="quote">you know if you got the polishing compound and a high speed buffer you wouldn't have needed the sand paper and saved 4 hours?</TD></TR></TABLE>
x2
heres mine after the high speed buffer:
x2
I don't have a high speed buffer. I was done in 5 hours, I didn't work that long.
Also, Big tip:
DON'T
FORGET
THE
BLUE
TAPE
(it works better when wet btw)
if you forget it, kiss your car paint goodbye. that's is unless you take the headlights out, which means dropping the bumper, and I didn't want to do that in the florida summer sun.
Also, Big tip:
DON'T
FORGET
THE
BLUE
TAPE
also check into canopy sandpaper, you can get it from 3M and it blows most sandpaper away. they measure their polishing ability in mircons. i have a set of 30, 15, 9 and 3 mircon pads and they will shine anything. here is a long and effective procedure. http://www.canopyfx.com/tips.htm
mac_24_seven
Apr 17, 2008 03:42 PM
Philbert
23
Feb 25, 2002 01:13 PM
