D15B axle help
Old Aug 10, 2007 | 04:44 PM
FSS13foxtrot's Avatar
Default D15B axle help
I have a crx HF with the original engine torn out and a d15b non v-tech . the axle went bad while i was driving and i had to replace it. i tried the hf axle, the dx/si axle and they dont work, any suggestions???This is a JDM engine
Old Aug 10, 2007 | 06:33 PM
welfarepc's Avatar
Default Re: D15B axle help (FSS13foxtrot)
which end of your axles wont fit? the transmission side? hub side? give more details
Old Aug 19, 2007 | 01:24 PM
Default Re: D15B axle help (welfarepc)
i tried the dx/si axle. the shaft was too long, and the transmission end was too round, it was wider as far as the housing. the axle end looked pretty similar. i tried the hf axle, it was the closest and it ran with it fine but eventually i had to get out and tighten it every 100 feet and it would make a grinding noise like it was not catching. possibly it could have been the hf just bad axle? i got it refurbished but sometimes thats not the best
Old Aug 19, 2007 | 05:37 PM
garageEF's Avatar
use hf/std axles. they are correct, maybe your just not doing it right??
Old Aug 21, 2007 | 07:40 AM
Default Re: D15B axle help (garageEF)
ill try it again and post what happens
Old Aug 21, 2007 | 09:15 AM
wiZCo's Avatar
Stouts 'n' Scotch
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by FSS13foxtrot &raquo;</TD></TR><TR><TD CLASS="quote">ill try it again and post what happens</TD></TR></TABLE>
If you're using the same transmission, then just get HF axles. If you're getting them from somewhere besides Honda, sometimes you'll have to try 3-4 sets before you find one that works.
b18c1mien
Mar 25, 2010 11:05 AM
EJ8CIVIC
Jan 20, 2009 12:17 PM
xtokex
Jan 25, 2008 05:09 PM
teknohatchie91
12
May 31, 2005 11:33 AM
JDM_DB8
Oct 8, 2004 06:24 AM
