ITR Factory intake question
Old Jun 12, 2002 | 08:23 AM
TurbothisLS's Avatar
Default ITR Factory intake question
hey,
what is the difference b/w LS and ITR intake systems from the factory?
I just got one from my friend and I dunno if I should use it. I have a crap no name brand CAI right now. THinking of going AEM or using the ITR factory system. What do you guys think?
Old Jun 12, 2002 | 08:27 AM
BlueR's Avatar
Default Re: ITR Factory intake question (TurbothisLS)
the R's intake has a hose that goes from the resonator box to the right side fender area effectively drawing "colder" air...hth
Old Jun 12, 2002 | 09:20 AM
ITRacer121's Avatar
Default Re: ITR Factory intake question (BlueR)
you would be better using the DIY intake (cheaper than AEM, worx better than factory, and wont hydrolock) posted on this board a few weeks ago.
I did this with a K&N and I am very intpressed! $12 in parts! $45 for K&N!
Old Jun 12, 2002 | 09:21 AM
hungsteR's Avatar
Default Re: ITR Factory intake question (ITRacer121)
Anyone have that DIY intake link?
Old Jun 12, 2002 | 09:41 AM
ALLMOTOR18's Avatar
Default Re: ITR Factory intake question (hungsteR)
i tried it.. i had a air scoop in the front of my car and that routed air into my airbox.. it was a ram air system..
it worked good; had good midrange, but the top end was weak..
i learned that nothing beats a CAI.. i use the Injen Race Division..
Old Jun 12, 2002 | 10:05 AM
BSQ's Avatar
BSQ
http://www.geocities.com/bretq/DIY_Icebox_CAI.html
Old Jun 12, 2002 | 10:31 AM
ee-gsr's Avatar
ITRacer121: do u know where i can get the K&N filter for $45? how is the DIY intake designed to prevent hydrolock?
TIA!
Old Jun 13, 2002 | 05:22 AM
BSQ's Avatar
BSQ
Default Re: ITR Factory intake question (ee-gsr)
Since the intake opening is directly behind the turn signal lense, there is reduced risk of ingesting water into the intake. Also there is a hole drilled in the bottom of the intake tubing to allow water to drain in the event that water happens to get into the intake. There is an additional hole drilled in the bottom of the airbox to prevent water from being draw up into the intake tubing. All these features are similiar to the Comptech Icebox.
Old Jun 13, 2002 | 05:29 AM
Dr Pooface's Avatar
hey,
I believe the LS intake is 2.5 inches in diameter, while the ITR's is 3. Don't know for sure, don't own an LS.
Old Jun 13, 2002 | 05:32 AM
1GreyTeg's Avatar
A.
Old Jun 13, 2002 | 06:47 AM
Cold Chunker's Avatar
Default Re: ITR Factory intake question (1GreyTeg)
Given that the piping is the same size, which I *think* that it is....seems like you just do a little cutting on your factory warm-air intake, like whacking the 90 degree bend off the end of it.....and presto chango, you have yourself a factory cold air intake! Right? Plus it weighs less!
Old Jun 13, 2002 | 11:57 PM
ALLMOTOR18's Avatar
Default Re: ITR Factory intake question (Cold Chunker)
just save your time and money... get a cai.. they cant be beat...
Old Jun 14, 2002 | 12:10 AM
EagleR's Avatar
Default Re: ITR Factory intake question (GSRTypeR)
I much prefer my CAI to the OEM
Old Jun 14, 2002 | 05:58 AM
YelLowITR's Avatar
well, i believe the ITR stock intake less noise than AEM, but still like AEM better
tempsohc
10
Apr 6, 2010 01:25 PM
Toda Built
Jan 21, 2010 07:10 AM
TurbothisLS
Jun 7, 2002 06:50 PM
RolioPolio
Mar 7, 2002 11:06 PM
