Y7 in an EF hatch
Old Aug 10, 2007 | 03:19 PM
nicko360's Avatar
* B A N N E D *
Default Y7 in an EF hatch
okay, i mated this motor to my SI tranny, its in a 91 dx, dual point to multi conversion
i switched over the distributer, resistor box, and put in some obd0 ls injectors
the motor starts up sometimes, but other times needs to be given gas
it runs for about 30 seconds then bogs down and dies
do i need to wire in the obd1 dizzy?
what else could this problem be? any help is appreciated. thanks in advance
Old Aug 10, 2007 | 05:01 PM
nicko360's Avatar
* B A N N E D *
Default Re: Y7 in an EF hatch (nicko360)
up
Old Aug 10, 2007 | 05:15 PM
neek175's Avatar
I've done the same swap in my ef si hatch. Luckily i didnt have to worry about the wiring because the car is an si. But all i did was reuse my si intake mani, si distributor, and si tranny and everything was fine. make sure you have a good dizzy. No do not use the obd1 dizzy unless you have the car wired for it. What ecu are you using?
Old Aug 10, 2007 | 08:11 PM
nicko360's Avatar
* B A N N E D *
Default Re: Y7 in an EF hatch (neek175)
its a jdm automatic zc ecu
Old Aug 12, 2007 | 12:23 AM
bobjohnson's Avatar
Why? Is youre car an automatic?
Just get the EF SI ecu.
twofatbrians
Jan 28, 2015 03:50 PM
efsedan2
Aug 1, 2008 01:27 PM
nicko360
Aug 10, 2007 04:59 PM
nickeynick
Jan 15, 2005 11:24 AM
