cable clutch issues
Old Aug 10, 2007 | 03:15 PM
racerpat94's Avatar
Default cable clutch issues
we just completed a cable LS swap into my brothers 90 DX hatch. MPFI conversion, customized the shift linkage, etc. etc. Now we are having a problem with the clutch.
the pedal has tension, but doesnt start engaging until the last 2 inches of travel, and it feels like it isnt engaging all the way. i have tried loosening the adjuster near the mounting bracket, but even with it all the way out, AND the rubber bushing removed from the ehd of the cable itself, it is engaging at te top and is a bitch to drive. am i adjusting it backwards?
Thanks.
Old Aug 11, 2007 | 12:34 PM
racerpat94's Avatar
Default Re: cable clutch issues (racerpat94)
Old Aug 11, 2007 | 01:22 PM
Aristotle's Avatar
Check and see if the pedal bracket is damaged or bent, sometimes when the car gets beaten on alot it gets bent or the welds on the bracket start to crack because of age and it causes it to lose tension. If so, then the whole front panel has to come off to remove that bracket. You might be able to find it at a junkyard but your better off going to Honda if you don't feel like doing twice the work. Good luck.
Old Aug 11, 2007 | 09:20 PM
Rd91SiB18ls's Avatar
What year is the tranny I have a 91 and a 92 the clutch cable brackets
are different I used the 91 I did have the 92 on it and the clutch was
really tight, Also check the cable on the pedal could be off the guide.
Good luck
Old Aug 12, 2007 | 04:34 PM
racerpat94's Avatar
Default Re: cable clutch issues (Rd91SiB18ls)
the tranny (and i assume the bracket) are from a 93 GS integra. the cable itself was in the 91 civic hatch when we got it, so i dont know if its a civic cable or a teg cable, or if there is a difference.
Old Aug 12, 2007 | 07:56 PM
g2daturbo's Avatar
either cable should work fine but i know the integra cable works mint!!! try getting an integra cable also what conditon is the clutch ??
Old Aug 14, 2007 | 03:14 PM
racerpat94's Avatar
Default Re: cable clutch issues (g2daturbo)
AFAIK its the original clutch with over 100K on it, so it might be going out. it never slipped when the engine/tranny was in my friends teg tho.
Old Aug 17, 2007 | 11:56 AM
Aristotle's Avatar
I'm not sure if there's a difference. I would think that the teg cable is longer though.
rasta420
Oct 18, 2002 12:33 PM
