Passenger window and rear failed at same time
Ok, just bought del sol-1993. Worked good when i was driving it home, now both the passenger and rear windows won't move. The fuses look good, what else could it be? Could both motors go at the same time, they were running great before.
The drivers master switch could have a bad connection, but the connection at both windows could be messed up as well. Might want to start with that.
at first i was thinking bad Run Chanel and/or Regulator... but i just had that happen to my civic and when those went out, they window still worked, just barely tho - check the connections, and if its not that, i am not too sure . . . Good luck!
ha ha... just bought a del sol too, and the same thing happened to me, in my case i flipped the switch labeled "main" on the driver's door and they rolled right up.
kryptekz
Aug 21, 2011 01:26 PM
hondapwr
Jul 17, 2009 05:30 PM
