Timing Belt installed ...valve adjustment necessary ?
Old Aug 10, 2007 | 10:31 AM
kornerk12's Avatar
Default Timing Belt installed ...valve adjustment necessary ?
The cams and valvetrain were not touched, however were adjusted a few months ago. I just changed the timing belt is it neccesary to do a valve adjustment after this installation ?
PS cam caps were not even loosend.
Old Aug 10, 2007 | 10:32 AM
Hawkze_2.3's Avatar
Default Re: Timing Belt installed ...valve adjustment necessary ? (kornerk12)
I'd check it just to make sure....may not need adjusting but who knows.
Old Aug 10, 2007 | 11:20 AM
giddyup21's Avatar
You should be fine if they were done right a few months ago, but again.. it never hurts to check. And it should only take ten minutes to get the valve cover off, use a feeler gage and then put the valve cover back on. Or thirty minutes if you need to adjust the valves.
Is there a reason why you're thinking you need a valve adjustment? If I were you I wouldn't worry about it unless something is making you think you need a valve adjustment.
Old Aug 10, 2007 | 12:11 PM
98vtec's Avatar
moderator emeritus
i'd check it anyway.
Old Aug 10, 2007 | 04:45 PM
slamdlude's Avatar
Default Re: Timing Belt installed ...valve adjustment necessary ? (98vtec)
never hurts to check while you have it apart already.
Marcg611
Aug 24, 2008 08:04 AM
stupifieded
Sep 8, 2007 07:43 AM
jdm4drSi
May 19, 2007 03:49 PM
VTECth1s
Jul 30, 2006 06:15 AM
vxnine
12
Oct 14, 2004 07:41 AM
