b16a wont start.
Old Jun 12, 2002 | 06:15 AM
mrduque's Avatar
Default b16a wont start.
Just did a b16 swap into my EF. When turning key to the on position I don't hear the fuel pump.. when trurning over i don't get a spark either.. I get no codes on the ecu and the check engine light comes on and stays on.. Shouldn't the check engine light turn on and recycle if there are any problems? I have a Hasport DX to SIR converted harness and sub harness. I believe everything is plugged in right in the engine bay.. i'm pretty sure it's plugged in right at the ecu. Please help!!!!!
Old Jun 12, 2002 | 07:23 AM
KevronsEG's Avatar
Default Re: b16a wont start. (mrduque)
when i did mine i had a ground not hocked up and the battery termenals wernt tight pluss i had a blown fuse under the dash. so check those
Old Jun 12, 2002 | 09:28 AM
chhuong's Avatar
Default Re: b16a wont start. (CIV616)
you have to check the codes on the ecu!!! the check engine light only blinks on 92+ cars!!
Old Jun 12, 2002 | 09:42 AM
DJ KrunchyKracker's Avatar
Default Re: b16a wont start. (chhuong)
i would say its a ground
Old Jun 12, 2002 | 12:01 PM
xXx Justin xXx's Avatar
the 88-91 you check the codes on the ecu. my friends b16, there is no LED light on the ecu to check the codes anymore. on my ecu conversion harness place racing made. i have a switch on it, click it one way the check engine light stays on, the other way it flashes codes. but i have changed everything to OBD-1 and run a 95 ex motor, so ....... good luck
Mesm23
Jun 13, 2017 09:11 AM
88crx Osaka
Aug 20, 2011 10:42 PM
tougetuned_ef
Jun 13, 2006 05:39 PM
EF-21
Mar 16, 2004 09:45 PM
petrv
Jan 4, 2002 07:37 AM
