dual point to multi point
Old Aug 9, 2007 | 08:08 PM
EFinSi's Avatar
Default dual point to multi point
i just bought a 89 civic dx hatchback an i was wondering what all i need to do to convert it to multi point when i swap i've never hade a dual point so can some on help me??? can i just use an si harness an distributor an computer an cal it good or what
Old Aug 9, 2007 | 09:42 PM
black0hatch's Avatar
Default Re: dual point to multi point (EFinSi)
nope. you need si intake manifold complete, si dizzy, si ecu, si resistor box and si plugs. then once you put all that on your dx motor you take your stock dx harness and add the fuel injector plugs and wireing for resistor box and wire in the dizzy plug then your done. kind of alot of work but it needs to be done. theres tons of detailed write ups.
Old Aug 9, 2007 | 10:06 PM
low91rex's Avatar
Default Re: dual point to multi point (black0hatch)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by black0hatch &raquo;</TD></TR><TR><TD CLASS="quote">nope. you need si intake manifold complete, si dizzy, si ecu, si resistor box and si plugs. then once you put all that on your dx motor you take your stock dx harness and add the fuel injector plugs and wireing for resistor box and wire in the dizzy plug then your done. kind of alot of work but it needs to be done. theres tons of detailed write ups. </TD></TR></TABLE>
Yeah that sums it up
Heres some links:
http://www.angelfire.com/d20/h....html
http://www.geocities.com/teampimports/fuelinj.html
http://www.geocities.com/c_rexboy/mpfi.html
http://hondaswap.com/swap-arti...9557/
Good luck
Old Aug 10, 2007 | 04:22 AM
CRX Toad's Avatar
Default Re: dual point to multi point (low91rex)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by low91rex &raquo;</TD></TR><TR><TD CLASS="quote">
Heres some links:
Good luck </TD></TR></TABLE>
https://honda-tech.com/zerothread/1508680
knightsef-eg
20
Jan 2, 2009 01:51 PM
Red_ED8
Sep 5, 2007 04:40 AM
TEAM HATCH-N-IT 90
Jan 27, 2005 06:07 PM
dingusjt
Oct 9, 2003 06:02 AM
TDRacing
Jul 29, 2002 07:37 PM
