fuel problem.. ef with ls
ok here is the run down. the fuel pump was bad so we replaced it with a walbro and then injectors went out. replaced those... now when we go to start car it cranks cranks cranks and eventuallly it will go to start then the engine light comes on and trys to catch on fire.. once it did..
to much fuel is comming out of exhaust..
motor: obd0-ls
ecu: obd0-ls
motor: obd0-ls
ecu: obd0-ls
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by gibsanez »</TD></TR><TR><TD CLASS="quote">Was this car previously a DPFI? If so, who did your MPFI swap, and do you have an injector resistor. </TD></TR></TABLE>
previously was dpfi. we did it
and yes it has resistor box
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by B16B_coupe »</TD></TR><TR><TD CLASS="quote">it cranks cranks cranks and eventuallly it will go to start then the engine light comes on and trys to catch on fire.. once it did..</TD></TR></TABLE>
it has caught on fire??!?
has the car ever run properly since the mpfi swap?
installed the regulator... and it starts now.. but the new injectors someone sold us was bad to.. so looks like we getting another set of injectors
sweetcarz02
15
Nov 2, 2004 06:40 PM
