Bad Mechanic
Old Aug 9, 2007 | 04:13 PM
Mike1995HondaPrelude's Avatar
Default Bad Mechanic
So I took my car to a mechanic to get the oil pan replaced. So he had me spray down the engine (I knew this was going to happen). Now the engine light is on. Also, the speedomotor didn't work for awhile. The time display keeps changing hours. When I got the car back teh antenna does not work properly.
when the radio is turned on, the antenna extends. when it stops extending, the motor is still running and makes a loud noise as if it still pushing up, even though the antenna has stopped extending.the same thing happens when the antenna retracts except the antenna stops about 2 to 3 inches short of flush. and when the antenna does stop, once again the motor continues to run making a loud sound as if wanting to continue to retract the antenna. i what do i do to fix this loud annoyance?
How can spraying down the engine harm it. I'll take it to autozone to see what the light means.
Any advice with the antenna? THANKS
Old Aug 9, 2007 | 05:28 PM
E-Money's Avatar
Default Re: Bad Mechanic (Mike1995HondaPrelude)
spray it down with water?
Old Aug 9, 2007 | 05:30 PM
DCxMagus's Avatar
just jump the OBD connector and pull the code
Old Aug 9, 2007 | 05:36 PM
Default Re: Bad Mechanic (E-Money)
ya, with water...
Old Aug 9, 2007 | 05:37 PM
Default Re: Bad Mechanic (DCxMagus)
Autozone does that right.. cuz i don't have a computer for that
Old Aug 9, 2007 | 05:39 PM
I just looked at the car. THE LEAK IS WORSE!!! NOW IT IS JUST DRIPPING OUT!!!!
I need a damn new mechanic. Any tips on finding a good one. Thanks
Old Aug 9, 2007 | 06:29 PM
DCFIVER's Avatar
Community Builder
Loved
Community Favorite
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Mike1995HondaPrelude &raquo;</TD></TR><TR><TD CLASS="quote">I just looked at the car. THE LEAK IS WORSE!!! NOW IT IS JUST DRIPPING OUT!!!!
I need a damn new mechanic. Any tips on finding a good one. Thanks</TD></TR></TABLE>
Look at the ASE website at there you will find certified mechanics..
Old Aug 9, 2007 | 06:38 PM
M2B4's Avatar
Default Re: Bad Mechanic (cb7-R)
learn to do it ur self lol
to pull ur code simply use a paper clip and jump the blue 2 pin conecter under cd player in console. obd1 will flash the check engine a series of flashes for the code. 1 long flash is 10 1 short is 1. (1 long flash 3 short = code 13) then just reference to the codes list u can find all over the internet.
Old Aug 9, 2007 | 09:05 PM
Fongman's Avatar
Default Re: Bad Mechanic (M2B4)
take your car to a honda shop and they will treat you right
Old Aug 9, 2007 | 09:12 PM
MLBZ521's Avatar
No, Autozone does not do that for your car. It has to be an OBD2. You are OBD1.
I wouldn't be worrying about fixing it yet rather than documenting everything, taking pictures of what's wrong now, talking to the guy that did the work, and possibly reporting it.
Nothing there sounds right...
Old Aug 9, 2007 | 10:23 PM
Default Re: Bad Mechanic (Fongman)
Soo what exactly is a honda shop? there is a place called hondoctors here but they told the guy that I bought my car from the engine my have a blown head gasket when the leakdown test showed less than 10% and it did run perfectly.
Old Aug 10, 2007 | 03:58 AM
giddyup21's Avatar
Are you sure it's coming from your oil pan? Did you cover your electrical components when you sprayed your engine down? There's like 5 common leak spots on a prelude engine (distributor o-ring, cam seals, head gasket, valve cover gasket, and oil filter cooler o-ring). I'd check to see exactly where it's coming from.
As for your CEL, do the jumper routine and you can find code lists all over this site. Fix what that says before you start worrying about individual problems like your antenna. Just put your antenna up and unplug the power to the motor if the sound of the motor is that annoying. Temp fix though.
Old Aug 10, 2007 | 03:29 PM
Default Re: Bad Mechanic (giddyup21)
Didn't cover the electrical components mechanic just said spray it down....
Nothing is coming from the head. I can't see any leak from the top looking down. seems like a lot of oil is around the oil pan gasket, but it was just replaced??? I'll ask teh mechanic to make special note of those places. Thanks
Can I check those without getting under the engine? Also, the car has an aftermarket cd player installed. Where exactly is the OBD1? THANKS A LOT!
HondaVerno
Mar 19, 2008 02:57 PM
mxteam
Aug 10, 2007 09:20 AM
shivsharma6
Apr 16, 2004 05:39 PM
Ben-VTEC
Feb 28, 2003 10:55 PM
