bad temp sensor maybe? overheating
Old Aug 9, 2007 | 03:54 PM
coolusername's Avatar
Default bad temp sensor maybe? overheating
so i was out driving my sedan, everything was running fine, then i look and see the temp gauge climbing up suddenly and quick. so i pull over immediately and shut the car off. pop the hood, and i dont see any signs of leaks, the overflow has coolant in it, and the radiator cap isnt even hot. fans are working. i turned the key back on, let the fans run and the temp dropped. i drove home, and the temp was going up and down, i would turn it off when it was at the H and turn it back on and it would only go to normal temp. im confused here. maybe the thermostat
Old Aug 9, 2007 | 03:56 PM
Default Re: bad temp sensor maybe? overheating (coolusername)
oh and this happens the day i take my new dd into the dealer to drop it off for the day. facckkk.
Old Aug 9, 2007 | 05:27 PM
anyone?
Old Aug 9, 2007 | 05:49 PM
Crx Jimmy's Avatar
if you have a spare sending unit throw it in. My last car would say it was always cold it would never warm up but the heat would blow fire hot. I changed the sending unit and the temp read normal like it is supposed to, Your best bet would be do get a cheapo no name $10 mechanical temp gauge and rig it in temporarily to see if you are really overheating.
Old Aug 9, 2007 | 06:13 PM
jayturboef's Avatar
try what crx jimmy said and if that dont work it could b tthe cluster...i had one go bad on me... good luck
Old Aug 9, 2007 | 07:06 PM
low91rex's Avatar
Default Re:
I had almost the same exact problem as you. only I never fixed it, It ended up overheating almost every day up and down I just thought it was playing games with me so I never fixed it. (i only work 10 mins away) The headgasket started to leak. But I dont have this motor anymore sooo I cant really help you sorry
Old Aug 10, 2007 | 03:52 AM
Default Re: Re: (low91rex)
will try that stuff today. thanks
eddie7978
Mar 22, 2018 08:33 AM
TOO MUCH TORQUE
Jul 28, 2010 09:21 PM
meanshyguy
Aug 24, 2008 07:50 AM
Chuethou_b18c5
Mar 15, 2007 10:46 AM
SPORT INJECTION
Oct 31, 2004 10:36 PM
