Easiest way to change the a/c belt?
Yes, there is a mount in the way. On my 94 Civic I had to loosen up the bolts holding the mount on b/c I didn't want to ruin the rubber in the mount. The mount is located behind your front wheel, a little behind your a/c compressor. There are two bolts going up holding on the mount I believe and I just put a jack with some wood under my oil pan, undid that mount, slid the belt around it, and then put the bolts back.
After that you just have to loosen up the tensioner and put the belt on, then tighten it back up. Just PM me if you have any questions or need any pictures, b/c I had trouble with the mount at first too.
From: new jersey home of wanna be's posers claimers ricers biters and where everyone fakes the funk
its pretty self explainitory. you can just drop the mount off the subrframe and slide the belt threw it..easy just check it out..youll see
mtrtbldr
Jun 10, 2017 04:56 AM
hondaless
Dec 31, 2005 03:24 PM
swappedcx
Dec 24, 2005 04:11 AM
