do u have a hard time shifting into reverse gear?
Old Aug 9, 2007 | 10:42 AM
crazyguy's Avatar
Default do u have a hard time shifting into reverse gear?
i have heard some honda owners have a hard time of getting the gear shift into reverse?
this happened to my hatch too
Old Aug 9, 2007 | 10:45 AM
Probot's Avatar
Default Re: do u have a hard time shifting into reverse gear? (crazyguy)
all hondas do...just weird...gotta like go into a different gear and then into reverse or just mess around in neutral and then go in...its weird. sometimes it just goes in though too -- pfshhh thats what she said
Old Aug 9, 2007 | 10:47 AM
andoxviii's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by crazyguy &raquo;</TD></TR><TR><TD CLASS="quote">i have heard some honda owners have a hard time of getting the gear shift into reverse?
this happened to my hatch too</TD></TR></TABLE>
Put it in nice and firm from a complete stop and you shouldn't have any problems.
Old Aug 9, 2007 | 10:49 AM
J.D.M's Avatar
I've noticed this as well, 'specially in my recently acquired Sol. As if the gearing is so wide that I have to rock the car a bit fore or aft to get the gear to engage e.e
thesmogman's Avatar
Default Re: do u have a hard time shifting into reverse gear? (andoxviii)
I have to pump the clutch one time. Works all the time like this.
Old Aug 9, 2007 | 10:52 AM
EkLanta's Avatar
Happens to me also. i got use to it. at a dead stop put it in first then reverse. or just dump it in reverse at the stop.
BlackoutVTi's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by andoxviii &raquo;</TD></TR><TR><TD CLASS="quote">
Put it in nice and firm from a complete stop and you should grind pretty good without any problems.</TD></TR></TABLE>
Lol, fixed. Give the clutch an extra kick, and gently try again. It's a common inconvenience more than a problem, and as a Honda owner, you just learn to deal with it.
Old Aug 9, 2007 | 10:54 AM
jdmnorice's Avatar
there is a couple of things one you might want to check your clutch or the position of the pedal or bleed the system or 5-r sleeve set is bad
Old Aug 9, 2007 | 11:02 AM
Jakester9500's Avatar
sometimes it will engage about halfway, then i just put it back in neutral and it goes in fine the next time
Old Aug 9, 2007 | 11:04 AM
instructor74's Avatar
Default Re: do u have a hard time shifting into reverse gear? (jdmnorice)
I have had this problem on more than just hondas. It is more common in high mileage cars. I have always just slide it into 1st then into reverse. Force of habit come to think of it I do that with every manual trans I have ever driven
Old Aug 9, 2007 | 11:06 AM
J.D.M's Avatar
Default Re: (Jakester9500)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Jakester9500 &raquo;</TD></TR><TR><TD CLASS="quote">sometimes it will engage about halfway, then i just put it back in neutral and it goes in fine the next time</TD></TR></TABLE>
Yeah, does this to me too. Just when I give it some gas it'll pop outta gear with a quick grind before finding itself in neutral
Great suggestions guys! Will give it a go!
Old Aug 9, 2007 | 11:09 AM
andoxviii's Avatar
Default Re: do u have a hard time shifting into reverse gear? (BlackoutVTi)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by BlackoutVTi &raquo;</TD></TR><TR><TD CLASS="quote">
Lol, fixed. Give the clutch an extra kick, and gently try again. It's a common inconvenience more than a problem, and as a Honda owner, you just learn to deal with it.</TD></TR></TABLE>
How do you figure? I do it everytime I go into reverse and have never grinded. I have only had problems putting it into reverse when I move the shifter slow into gear. I'm not saying you have to punch the reverse gear as hard as you can, but putting it in firmly has always worked for me.
Old Aug 9, 2007 | 11:14 AM
tEKnics's Avatar
if i put it in nice and firm as you suggest and let the clutch out i hear a nice grind
tEKnics's Avatar
Default Re: do u have a hard time shifting into reverse gear? (tEKnics)
i usually just put it into first and the move it to reverse...seems to work for me
Old Aug 9, 2007 | 11:26 AM
Point taken. Thought you meant giving it a forceful shift, which has always resulted in a grind for me (I've done it when having a bad day)
Old Aug 9, 2007 | 11:28 AM
95vxtealhatch's Avatar
When shifting into reverse try putting it into 2nd then 4th and then reverse.Or hold it in reverse while letting the clutch out slowly until you hear a click, and the shifter goes back a lil bit more. Now your actully in reverse.
Reverse is not syncromeshed its actully a straight gear somtimes it takes a lil finess to get into reverse. Atleast ever tranmission ive seen had a straight gear for reverse.
Old Aug 9, 2007 | 11:34 AM
Default Re: (95vxtealhatch)
This is true ^^^
Old Aug 9, 2007 | 11:47 AM
n1_egsex's Avatar
* B A N N E D *
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by tEKnics &raquo;</TD></TR><TR><TD CLASS="quote">i usually just put it into first and the move it to reverse...seems to work for me</TD></TR></TABLE>
Old Aug 9, 2007 | 12:27 PM
fitbmx86's Avatar
yea i think a lot of cars i have driven do this. it happens on my friends wrx more than it does in my car
Old Aug 9, 2007 | 12:34 PM
andoxviii's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by 95vxtealhatch &raquo;</TD></TR><TR><TD CLASS="quote">Or hold it in reverse while letting the clutch out slowly until you hear a click, and the shifter goes back a lil bit more. Now your actully in reverse.</TD></TR></TABLE>
This always works
Old Aug 9, 2007 | 12:38 PM
EG6 Love's Avatar
my hatch always does that... i jus put it in N and let the clutch out then right back in and usually it goes right to R
Old Aug 9, 2007 | 12:45 PM
94hatchling's Avatar
i always do 4th then Reverse. if not that, then 2nd, 4th, Reverse....
if its REALLY stubborn, i put it back in 1st bump forward a little (pretty much that the clutch kinda engages), then she slips right into Reverse.... this works EVERY SINGLE TIME.
those work always work for me.
Old Aug 9, 2007 | 01:07 PM
dnaman's Avatar
Put it on 4th gear, an then reverse, it works very well.
Old Aug 9, 2007 | 01:46 PM
CapnKrunch's Avatar
Default Re: (dnaman)
My reverse usually grinds unless I put in the clutch and rev it up to 2 grand, then I pop it into reverse slow and works perfectly for me.
Old Aug 9, 2007 | 02:14 PM
5_Lug_B's Avatar
* B A N N E D *
Default Re: (CapnKrunch)
My reverse sucks, but 1 - 5 are awesome. Gotta love JDM R trannys
