93 accord brakes go to the floor when i use a/c
Old Aug 9, 2007 | 06:38 AM
ddg2sailor's Avatar
Default 93 accord brakes go to the floor when i use a/c
The topic pretty much says it all.
Robert
Old Aug 10, 2007 | 06:50 AM
tjluvsahonda's Avatar
Default Re: 93 accord brakes go to the floor when i use a/c (ddg2sailor)
More than likely, it's the master cylinder... had this same problem when I had a 92 accord... fixed the problem immediately.
Old Aug 10, 2007 | 10:49 AM
ddg2sailor's Avatar
Thats was i was thinking also.
Thanks
Old Aug 14, 2007 | 06:58 AM
ddg2sailor's Avatar
Ive been thinking about this. As the breaks work fine when I dont use the ac maybe a fluid flush will fix it... it seems aweful thin and maybe the heat is causing an issue.
Robert
Old Aug 14, 2007 | 08:57 AM
JimBlake's Avatar
Default Re: (ddg2sailor)
That happened on my former '95 Integra. I tried flushing the brake fluid & it was only a temporary fix. Couple weeks & it was doing it again. I had to replace the master cylinder.
Old Aug 15, 2007 | 09:39 PM
ddg2sailor's Avatar
Im stuck between a rock and a hard place here. Other then when I use the ac and some time after that , the breaks work fine.
While I would like to use the ac I dont have money to change a master cylinder that otherwise seems to work fine.
I am grateful for your feedback though.
Old Aug 16, 2007 | 03:18 AM
JimBlake's Avatar
Eventually it'll start happenning when you don't have AC turned on. May as well get prepared for that. Save up & don't drive close behind me.
Old Aug 16, 2007 | 08:25 AM
361 accord's Avatar
Default Re: (JimBlake)
i think jim's got it, but why is this only happening with the a/c on?
Old Aug 16, 2007 | 08:36 AM
Duane_in_Japan's Avatar
Default Re: (361 accord)
Its not expensive to get a rebuild kit, you should not need an entire master cylinder, clean it good with brake/parts cleaner and do a complete 4 wheel brake bleed/flush with plenty of new fluid.
Old Aug 16, 2007 | 11:04 AM
JimBlake's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by 361 accord &raquo;</TD></TR><TR><TD CLASS="quote">i think jim's got it, but why is this only happening with the a/c on?</TD></TR></TABLE>I don't know, but my Integra started out that way. Higher under-hood temperatures cause it to happen more. But it seems that the problem comes & goes with the AC more quickly than the AC can influence under-hood temperatures. I figured the cost of a new MC was cheaper than jacked-up insurance after hitting something.
Old Aug 17, 2007 | 11:04 AM
ddg2sailor's Avatar
Even with the a/c on the brakes still work , just not with the margin of comfort i would like , but far from failing.
Im inclined to think it is a heat issue.
Jim , thus far the brakes are working not badly... fact is Im so over careful that I try to anticipate problems before they become problems. Trust me when I say I wont even let the brakes get so bad that I would risk an accident.
I am grateful for the feedback of all you nice people.
Old Aug 20, 2007 | 08:10 AM
JimBlake's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by ddg2sailor &raquo;</TD></TR><TR><TD CLASS="quote">Jim... Trust me when I say I wont even let the brakes get so bad that I would risk an accident.</TD></TR></TABLE>
That's good. I meant what I said as friendly hassling; I'm not trying to be mean...
It was my experience that flushing it with fresh fluid was a very temporary fix.
msnewman
Jul 19, 2011 12:37 PM
sandjunky
Jul 17, 2010 05:46 AM
slicermage
Aug 5, 2006 07:27 PM
thelate1
Jun 1, 2005 03:23 PM
klp
Jun 1, 2004 08:24 PM
