dpfi to mpfi troubles
Old Aug 9, 2007 | 05:42 AM
dem0nk1d's Avatar
Default dpfi to mpfi troubles
so i'm now in my engine bay doing the wirring for the injectors my question is this.
"Injectors and injector resistor box
Connect the yellow/black wires from the two DX injector harnesses and run it to the yellow/black wire on the injector resistor box.
1. Connect the yellow wire from the DX injector to the #1 injector (brown wire).
2. Connect the red wire from the DX injector and run it to the #3 injector (blue wire).
3. Connect the A3 wire to the #2 injector (red wire).
4. Connect the A7 wire to the #4 injector (yellow wire).
5. Connect the 4 red/black wires from injector resistor box to each injector.
When talking about the yellow wire. Which one? Use the yellow wire that is with the red wire or the Yellow/Blk wire? Or does it matter here is a pictrue of the plugs.
Old Aug 9, 2007 | 05:59 AM
mahatma's Avatar
Default Re: dpfi to mpfi troubles (dem0nk1d)
solder the 2 yellow/black wires (from each of those green plugs) together. then solder them to the resistor box. then each of the 4 wires coming from the resistor box will power each injector - in no particular order.
*edited the rest because i got it all wrong LOL*
Modified by mahatma at 10:21 AM 8/9/2007
Old Aug 9, 2007 | 06:21 AM
dem0nk1d's Avatar
i think you got it wrong. the blu/ylw + black/ylw = evac. the green plug with yel/blk and solid yellow is the old dx injector. the one that's cut and has the red and solid yellow wires shrink wrapped to the other wires are the other injector. i think this use to be a brown plug if i can remeber. it's laying around on the floor of the garage. but i'm at work.
Old Aug 9, 2007 | 06:23 AM
mahatma's Avatar
Default Re: dpfi to mpfi troubles (mahatma)
each of the 2 original dx injectors should have a yellow/black wire
are you positive that the wire in the very bottom of the pic is solid yellow and not yellow/black?
Old Aug 9, 2007 | 06:25 AM
dem0nk1d's Avatar
okay so your saying the yellow / black and black yellow need to be connect together. See i've done this swap like years ago at least 7 years ago i kind of forgot.
yeah they are both solid yellow.
Old Aug 9, 2007 | 06:27 AM
dem0nk1d's Avatar
also if i am using obd1 injectors all of my yellow/black wries from my mpfi injectors will tie into the yellow black, wire and no need for a resistor box
Old Aug 9, 2007 | 06:47 AM
mahatma's Avatar
Default Re: (dem0nk1d)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by dem0nk1d &raquo;</TD></TR><TR><TD CLASS="quote">also if i am using obd1 injectors all of my yellow/black wries from my mpfi injectors will tie into the yellow black, wire and no need for a resistor box
correct, no resistor box. just lump all the power wires together, and make sure that each injector gets a little piece of that action
if i remember correctly, stock obd1 injector power wires are red/black, just fyi
but when you get home, double check that you're dealing with the correct plug. because i'm pretty sure that each original dx injector is powered by a yellow/black wire. other than that, the instructions you posted look spot on.
Old Aug 9, 2007 | 06:58 AM
dem0nk1d's Avatar
it would make sense that the solid yellow wire would be from the injector that has the yellow/black wire. the other injector that has the red wire, and the wire that looks like a solid yellow should actually be yellow /black and not solid. this way i could see all wires being used.
Old Aug 16, 2007 | 02:43 PM
shervang9's Avatar
okay I'm doing the same swap too! D15B1 dpfi to mpfi... I've done everything by the book and now my car is in limp mode! Let me know how your swap goes when you're done! Maybe i got something wrong or just got to check my connections at the ecu pins... (those pins are a PITA )
Old Aug 16, 2007 | 02:58 PM
dem0nk1d's Avatar
https://honda-tech.com/zerothread?id=2067609
jdm206
10
Apr 22, 2007 02:40 PM
Tippyman
14
Mar 27, 2006 08:55 PM
ivanson
25
Nov 15, 2005 09:04 PM
Magic Wheels
Jul 17, 2004 02:03 PM
zccrx
Apr 2, 2003 07:03 AM
