STARTING UP THE CAR???
Old Aug 8, 2007 | 08:47 PM
thambi23's Avatar
Default STARTING UP THE CAR???
I HAVE A PROBLEM WEN I START UP MY CAR IT WILL START BUT IT HESITATES TO START....BUT IT RUNS FINE NO KICKIN BACK OR NUTTIN BUT ITS JUS WEN I START MY CAR SOMETIMES WEN I TURN THE KEY TO TURN ON THE CAR IT STRUGGLES> WUT SHOULD I DO
Old Aug 8, 2007 | 10:01 PM
dwayne1413's Avatar
Default Re: STARTING UP THE CAR??? (thambi23)
Whoa killer no need to yell!
Have you tested your battery? When was the last time you replaced it? my car takes a few clicks to turn on because my battery is dying. When your driving on an empty tank the car also takes a few clicks to come on because the fuel pump is sucking in so little gas.
Old Aug 9, 2007 | 02:04 AM
slomob18b's Avatar
Default Re: STARTING UP THE CAR??? (dwayne1413)
If your battery is good, look into your starter as the contacts inside may be worn.
Old Aug 12, 2007 | 11:29 PM
thambi23's Avatar
alright thanks man
lawlss
15
Sep 14, 2009 10:23 PM
filipinospeed
Jun 11, 2009 07:14 PM
juanambriz7
Nov 21, 2007 04:56 PM
wreckedmyteg
Apr 20, 2006 09:23 PM
Silvteg95
Nov 21, 2005 10:45 AM
