where is the door pin switch located?
Old Aug 8, 2007 | 07:40 PM
blinger's Avatar
Default where is the door pin switch located?
on a 96 coupe
Old Aug 8, 2007 | 08:26 PM
shadowdancer's Avatar
Default Re: where is the door pin switch located? (blinger)
should be in the door jamb. its usually a little push button thing. are you looking for wiring colors?
Old Aug 9, 2007 | 02:58 PM
blinger's Avatar
Default Re: where is the door pin switch located? (shadowdancer)
im wanting to wire up an alarm and its asking for the door pin switch + or -
Old Aug 9, 2007 | 07:32 PM
blinger's Avatar
come on now, i know someone knows something about this!
i'm guessing the door pin switch is the button to tell that the door is open? Will I be using the wires off of that switch?
Old Aug 9, 2007 | 07:39 PM
DCSportEJ1Civic's Avatar
wow, those alarms are a pain in the ***. ive done 4 of them for myself and friends.
http://64.85.6.121/diagrams/pr...eID=3
ive never done it on that car tho. the diagram i found says its in the driver side kick panel. it also says its a negitive trigger. id suggest goin to a honda dealer, tell them what ur doing and what you need and they should be able to print you a better diagram. and yes thats so the alarm knows if the door is open or not. so if the system is armed and the door opens it will set off the alarm. good luck. id say do some more research tho.
Old Aug 9, 2007 | 08:12 PM
pain in the ***? your joking right?
Here's your info your looking for:
HONDA, CIVIC, 1996, Door Trigger
Light Green with a red stripe / it is negative trigger
Also found in the green factory alarm plug located behind the radio.
Can also be found in a light green plug above the fuse box or bottom of driver kick, harness to rear.
Old Aug 10, 2007 | 10:43 AM
blinger's Avatar
Default Re: (shadowdancer)
what do they mean by "cut starter wire for starter interrupt relay connection"?
felixjr18
Acura TL, RL & ZDX
May 7, 2009 03:26 PM
PatrickGSR94
Feb 6, 2009 08:51 AM
LaOstha
Dec 24, 2006 04:48 PM
TehMoonRulz
Jun 29, 2005 09:31 AM
chansw
Jun 3, 2004 02:40 AM
