HOW DO I INSTALL NRG SHORT HUB ON A 03 civic
can any1 please help?? i want to install a nrg short hub onto a 03 honda civic LX. anybody know how to?? if possible can you please send a step by step thanks alot
If you plan on using a Nardi wheel, you'll need either a quick-release setup, or some sort of converter for the wheel to mount to.
This is roughly the same install procedure:
http://www.weaksauceforums.org/viewtopic.php?t=535
You'll need to remove two size 30 Torx screws to get the airbag unit off of the wheel, then a 19mm socket to unbolt the wheel from the steering shaft. I'll have a tutorial up this weekend, on where the horn wire lead is on the harness-side.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by jdmchris626 »</TD></TR><TR><TD CLASS="quote">thanks man.. im using a nrg short hub with nrd quick release.. then im using a momo wheel...</TD></TR></TABLE>
You'll be fine then. I'll have that tutorial up this weekend, so you'll know where to tap in for the horn to work.
ekhatchey
Jan 10, 2008 06:15 AM
