Car fires up for the first time after done the swap (b16a SiR II)
my eg hatch fires up for the first time after done the swap B16A JDM SiR II
but the check engine light came on and also the battery light came on too?
ok i checked the code ..it is
41 Primary oxygen sensor heater
is it because the header is not connected to the cat..
cause the flanges dont match up
i have to have a muffler shop to weld them on
does that mean i have a bad o2 sensor?
if thats the case then thats a piece of cake to get it replaced
Modified by crazyguy at 5:12 PM 8/8/2007
Modified by crazyguy at 5:17 PM 8/8/2007
Modified by crazyguy at 5:20 PM 8/8/2007
exactly what sort of help do you want with a check engine light if you don't supply the codes?
how bout you pull the codes, and go to the faq at the top of the page that deal with CEL codes.
ph0shizzle
May 13, 2006 08:36 PM
97gSrkId88
Mar 20, 2003 11:06 PM
no offense op
