High Idle....Codes 5. 7. and 14
Old Aug 8, 2007 | 02:57 PM
tigerjuice's Avatar
Default High Idle....Codes 5. 7. and 14
I fixed one issue and now have to fix another. I can't seem to get the idle down, the cable adjustment is fine i.e its not to tight.
I am not for sure what the piece is on the side of the throttle body near the blade but its a rod that goes into a diaphragm type piece and when I push it in the idle goes down but as soon as I let off the rod it starts idling high again.
Any ideas?
Thanks
Old Aug 8, 2007 | 03:00 PM
garageEF's Avatar
Default Re: High Idle....Codes 5. 7. and 14 (tigerjuice)
your cable is too tight...try taking the cable off and starting it.
Old Aug 8, 2007 | 03:19 PM
tigerjuice's Avatar
I took the cable completely off and it still idles high.
On startup it idles fine for about 5 seconds and then the check engine light comes on and it immediately idles high again.
I don't have a tach however I am going to take a guess that its idling at 1800 or so.
Still codes 5,7 and 14 exist.
FATKID87
Honda CR-V & Element
Mar 26, 2014 07:52 AM
dougsunny
Jul 19, 2010 06:00 PM
bardeal2
10
Jul 30, 2007 04:51 PM
1993gsrcivic
May 4, 2007 11:41 AM
LillDragun
May 3, 2002 03:00 AM
