FS OVER 500WHP 95 Integra Built By King Motorsports (Testing Waters)
<U> NO LONGER SELLING</U>
This is a 95 GSR that motor, tuning and trans was done by king. Have receipts for work and parts. Any Questions Im Me.
This includes full motor build, trans build, brand new turbo, piping, and so on. Body and paint is in great condition. and everything works. Asking $17,500 obo
Here is a list
®Balanced and Blue Printed B18C by King MotorSports
®ITR Cams
®J E Pistons 84.mm with eagle godzilla sleeved block
®Eagle Rods
®New Main Bearings
®ITR Balanced Crank
®New oil pump
®New Mugen low temp thermostat
®Samco red coolant hoses
®J G Intake Manifold
®King Big bore throttle body
®LoveFab Ram Head exhaust manifold (2800° Ceramic Coated)
®Moroso 5 Qt oil pan
®Precisions version of the Garrett gt35r turbo– Polished housing (2800° Ceramic Coated Turbo Housing)
®40mm Tial Wastegate
®HKS sequential blow off valve
®Integra type R cylinder head Port matched, 3-angle competition valve job
®Type R Cams
®Supertech valve train
®ARC intercooler
®Mugen Hard Motor Mounts
®Fluidyne 40mm radiator
®Precision 1000cc injectors
®3-inch stainless steel exhaust
®3-inch stainless steel down pipe (2800° Ceramic Jet Coated)
®Walbro fuel pump 225 LPH
®AEM fuel filter, fuel rail, cam gears
®KMS oil catch can
®Magnacore 8.5 plug wires
®MSD full sport compact ignition
®Custom upper & lower intercooler pipes
®ACT stage 3 six puck racing clutch
®Act 8LB Flywheel
®Quaife Limited slip
®Built Trans (hardened and carbon coated components)
®Enkei J10 17x7 rims w/Falken Azenis rt615 205 40 17
®Front Brembro cross-drilled and slotted rotors
®Rear Brembro cross-drilled rotors
®Brembro front & rear brake pads
®Tokico Illumines coil-overs
®DC sports front & rear strut tower braces
®Hondata P72 ECU
®Hondata S300 computer system
®Hondata Independent gear boost controller
®Sparco Flash 5 steering wheel
®Sparco Pedal Set
®Full chrome moly roll cage
®Sparco racing seats
®Sparco 4 point Harnesses
®Jdm Air bag Eliminator Plate
®JDM Center counsel Eliminator
®JDM double Din Stereo Eliminator Plate
®Mugen Sweat Socks
® 01 ITR Stock Front Bumper cover
® 98 Stock Head lights
® 98 Stock Rear Bumper
®Gauges auto meter phantom series (fuel pressure, oil pressure, volts, boost, nitrous,
Air/fuel) 5.5” auto meter tachometer with shift light
Modified by 501hpintegra at 9:36 AM 8/9/2007
Modified by 501hpintegra at 1:12 PM 8/9/2007
Modified by 501hpintegra at 1:18 PM 8/9/2007
Modified by 501hpintegra at 2:29 PM 8/9/2007
Modified by 501hpintegra at 11:04 PM 8/12/2007
Here is a list
®ITR Cams
®Eagle Rods
®New Main Bearings
®ITR Balanced Crank
®New oil pump
®Type R Cams
®ARC intercooler
®KMS oil catch can
®Act 8LB Flywheel
®Hondata P72 ECU
®Sparco Pedal Set
®Mugen Sweat Socks
500whp and no mention of a sleeved block...no mention of what pistons, etc... MAN! when you sell a car for that much money you have to tell people EVERYTHING... Lower that price too, or atleast keep those wheels and seats and that steering wheel and lower it...WI bump.
man when you look ata car for sale you should check the list because at the very top gives you ever detail including sleeved and pistons. Usually when you say a full built motor you can assume that the engine is built right! The price your right maybe i could lower the price on it which I did but also that what it means to take offers. Thanks for the bump tho. I tried to get every detail out there so bear with me and like I said and question's just IM me.
Modified by 501hpintegra at 1:20 PM 8/9/2007
Sorry but Im going to have to disagree with you when you say you can "assume" someones motor is built right when it states its "fully built". No matter what you say or leave details about no one ever really knows whats in this motor unless they physically take it apart or if they were actually there watching the motor being built.. Still a PIMP *** car though.
501hpintegra
Nov 15, 2007 12:48 PM
501hpintegra
Oct 24, 2007 08:20 AM
501hpintegra
Aug 13, 2007 12:38 PM
W
