Honda Civic (2006 - 2015) 2006 - 2015 Civic Forums
Adding oil to the "break in oil"
Old Aug 8, 2007 | 12:23 PM
Default Adding oil to the "break in oil"
i check my oil religously due to the fact that im a psycho, i have 2k on my car and i added castrol 5w30 (non synthetic) to fill it up to the second hole on the dipstick. Is that ok to mix with the break in oil????
Old Aug 8, 2007 | 12:56 PM
Mechanic's Avatar
Default Re: Adding oil to the "break in oil" (RR"The Deuce")
Yes. The factory fill is conventional ExxonMobil 5w-30, but Castrol 5w-30 is an excellent oil. The two are entirely compatible.
Old Aug 8, 2007 | 01:03 PM
Thanks, i feel a little bit better now!
Old Aug 8, 2007 | 02:21 PM
Alex_G's Avatar
Occupy GDD
Default Re: ("Ridge"Racer)
Hmm I've always been told mixing different brands of oil is a no no but I can't say for sure if its true.
Old Aug 8, 2007 | 02:23 PM
thats funny, ive heard quite the opposite, in fact, ive heard that its ok to mix synthetic with regular oil, at least to top it off. well im no expert and you may be correct so hopefully someone smarter than us can tell us for sure!
Old Aug 8, 2007 | 02:27 PM
Bulli Kid's Avatar
its perfectly fine dont even sweat it. if hybrids can run on olive oil we can mix oil lol
Old Aug 8, 2007 | 05:22 PM
burnout8488's Avatar
You can mix any type of oil, brand of oil, and any viscosity of oil you like and nothing *bad* will happen.
If you needed to top off your factory fill, thats better than running it low on oil because you didn't want to mix them!
FitsMe
Honda Fit
Apr 16, 2012 05:05 AM
EG_Civic_Si
Feb 6, 2011 04:05 AM
highwhey
Nov 11, 2010 05:53 AM
blkbeast
May 28, 2003 10:48 PM
