obd0 b16a vaccum verification needed
ok, i've been looking for some a diagram now for quite some time. all i can find is ones that don't have the same setup as my engine. for example, here's one i found
my stock b16a does not have the spot where number 10 goes to on the manifold. it's just not on the manifold.
also, i have some(stock) device mounted on the intake mani near middle of where the throttle adjuster bolts and the throttle itself meet w/the throttle cable, and it has a vacuum hose on it, and it doesn't show that on here either. it looks like a regulator of some sort.
so, this diagram clearly is not what i need.
I DID however find this one while searching.
does this look correct for my setup?
also, that diagram still does not have the device on my mani with the vacuum hose on either.
if neither of these are correct, does someone happen to have a correct diagram? thanks.
Modified by freak86 at 1:16 PM 8/8/2007
ej8_fredi
May 13, 2009 12:51 PM
japrex
Dec 22, 2004 06:42 PM
smokinvtecCRX18
May 13, 2003 08:35 PM
