FS: '84-87 CRX HF/Si Parts Blowout! Two parts cars worth, still some left over
Old Aug 8, 2007 | 11:01 AM
MakDiesel's Avatar
Default FS: '84-87 CRX HF/Si Parts Blowout! Two parts cars worth, still some left over
Super '84-87 HF/Si CRX Sale! ***PICS BELOW***
All parts fit '84-87 CRX HF/Si 5-speed unless otherwise noted. I've never thrown parts away but I'm close to it just to get my closet back!
Pick a number(s), make an offer, bring cash, combine numbers for discounts and happy hunting.
I'm currently only taking local offers (pickup only) once that drys up I'll start shipping the smaller stuff, then ebay, then the dumpster.
It all MUST go! I am located in Winston-Salem, NC 27104
***If it looks like it's been sprayed black, it has been sold***
1. HF brake booster and master cylinder
2. Si stock clutch disc and pressure plate, very little wear on disc
3. Manual pedal assembly, comes w/ clutch cable
4. Misc. interior items (glove bbox, dash tray, rearview mirror)
5. HF solid discs (rusty, need to be turned), and calipers
6. Blower for heat/air
7. Taillights (one has small chip in plastic) w/ choice of 2 center pieces, one w/ "CRX", one painted black
8. Complete Si rear wiper (motor, wiper assembly, wiring harness)
9. More misc. interior (steering wheel, upper/lower covers, visor, turn signal stalks)
10. HF interior relay/black boxes/green boxes/emissions/fuse box medley, clutch switch, brake switch, heater control attachment
11. Gauge surround w/ no attachments (i.e. just the frame)
12. Pair of pretty decent '86-87 headlights, glass is perfect, frames are a little beat but functional, little overspray on one but can easily be cleaned up
13. Set of 4 mudflaps (rears fit my '85 Si, but fronts DO NOT, not sure if they are for hatch or sedan)
14. Complete A/C from my '85 CRX Si (compressor, condensor, lines, brackets, fan, etc)
15. Pass. side corner and both front ambers, usable but not show pieces
16. Driver side mirror w/ backing plate, missing a few screws, a few scratches on front, glass is good, daily driver piece
17. Pass. side mirror w/ backing plate, missing a few screws, glass is good, what you would expect of a daily driver piece
18. '85 Si front rotors and pads (discs might need a turning, pads have plenty of meat left)
19. Hood pins, lil rusty
20. CRX ignition w/ key
21. Interior emblem/delete medley (steering wheel "H", defrost delete, clock delete, fuse box cover)
22. Exterior emblem medley ("Honda", "Civic", big "H", "HF")
23. Brand new Warner 12v, 30watt, offroad lights (set of 2, new in boxes)
24. '85 Si used water pump, tensioner, timing belt (unknown miles but I have them as my backup in case of emergency repair)
25. Stock '85 Si air box (not pictured but includes air filter, box, resonator [pictured], does not inlcude intake tube that connects to throttle body, however)
26. Choice of two stock '88-91 Si/DX Driver's side axle, one very good condition, boots are fine, comes w/ axle nut, the other is busted but can be used as a core
27. Audiobahn 1400Watt peak, 700Watt RMS model AW1200Q High Excursion 12" sub, used less than 3 months in my old ZX ~ $50
28. 2 Sony Xplod 12"s, 1200w/ea, w/ Sony Xplod 1200w Amp, all in a carpeted box ready for hookup, nice trunk thumper. ~ $225
29. Autotek Mean Machine "Cheater" Amp, rated at 50x2, actual power is more like 1800watts. Model # is HC250Mxi, 100 watt into 4 ohms. $300 Firm, was originally $999
***EDIT -- The pics aren't showing up so here are the links***
http://www.redpepperracing.com...dex=1
#27
http://www.redpepperracing.com....html
#28
#29
91zSi
Jul 26, 2005 03:14 PM
91hatchcivic
Oct 15, 2004 05:51 AM
JBk24crx
Oct 13, 2003 07:34 PM
Brood11384
May 4, 2003 09:41 PM
