02 SENSORS
Old Aug 8, 2007 | 10:49 AM
juanchoenuncrx's Avatar
* B A N N E D *
Default 02 SENSORS
THE SI HARNESS ONLY HAS ONE 02 SENSOR AND THE B16 NEEDS TWO SENSORS CAN I USE ONLY ONE OR DO I HAVE TO DO SOME WIRING TO MAKE IT RUN PROPERLY??????
Old Aug 8, 2007 | 11:13 AM
wiZCo's Avatar
Stouts 'n' Scotch
Default Re: 02 SENSORS (juanchoenuncrx)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by juanchoenuncrx &raquo;</TD></TR><TR><TD CLASS="quote">THE SI HARNESS ONLY HAS ONE 02 SENSOR AND THE B16 NEEDS TWO SENSORS CAN I USE ONLY ONE OR DO I HAVE TO DO SOME WIRING TO MAKE IT RUN PROPERLY??????</TD></TR></TABLE>
You will need to wire in the second one.
Old Aug 8, 2007 | 06:11 PM
powerpro_69's Avatar
Default Re: 02 SENSORS (wiZCo)
do u have any pics of where u put them at
Old Aug 10, 2007 | 05:11 AM
* B A N N E D *
Default Re: 02 SENSORS (powerpro_69)
i put only one wich is near the converter is in the header but is downstream that the only one i have since the harness is obdo and the b16a1 ecu is obd0 i dont see why im i supposed to get two sensors these weekend i will fired up to see what happens
Old Aug 10, 2007 | 05:59 AM
placid888's Avatar
you have an aftermarket header? or stock header? if it's aftermarket then your car will run like ****, because O2 behind the cat doesnt monitor air/fuel ratio
Old Aug 13, 2007 | 12:53 PM
* B A N N E D *
Default Re: 02 SENSORS (placid888)
what if i put one on the upper part like drill a hole and install it? will that be good????
hondafdj444
Feb 12, 2014 11:23 AM
aaronhume
Aug 10, 2006 08:54 AM
c1v1c98
Jul 25, 2006 08:23 PM
scul8r1990
May 22, 2005 07:25 PM
JeremyL
Dec 26, 2002 07:54 PM
