Metal Cutting Saw Blade Help!
Old Aug 8, 2007 | 10:46 AM
Ohgodzirra's Avatar
Default Metal Cutting Saw Blade Help!
I'm looking for a good 10" 5/8 arbor metal cutting saw blade. Every where I look or call seems to just have general purpose construction, which is the description of the blade I have no but its destroying itself cutting thin wall mild steel. I'm looking for a blade that will make smooth flush cuts, I know there will always be some residual material leftover, but basically a blade that would cut quick, smooth, and last a while.
Old Aug 8, 2007 | 11:51 AM
Ohgodzirra's Avatar
Default Re: Metal Cutting Saw Blade Help! (Ohgodzirra)
Oh, I would want to be able to cut 16g mild and ss 304 with it, nothing crazy, maybe some braided ss line from time to time as well.
Old Aug 8, 2007 | 01:49 PM
Sims's Avatar
Are you using a woodworking chop saw? If you are, about your only choice is going to be an abrasive blade...
Old Aug 8, 2007 | 07:12 PM
Ohgodzirra's Avatar
Default Re: Metal Cutting Saw Blade Help! (Sims)
aww son of a, it's a craftsman so I'll just assume its woodworking only. I didn't know there was a difference for them, I assume it has to do with rpm?
sflkgjsfndgn
Welding / Fabrication
14
Oct 1, 2014 06:59 PM
xander1100
10
Sep 5, 2009 07:48 PM
eclypzex
Dec 10, 2008 03:11 PM
hulkhb
Jul 25, 2004 12:13 AM
turbo hybrid hatch
Jan 21, 2002 09:02 AM
