obd-0 to obd-1 conversion harness
Old Aug 8, 2007 | 08:47 AM
dem0nk1d's Avatar
Default obd-0 to obd-1 conversion harness -heLP-
I am about to finish my DPFI to MPFI conversion tonight. Then i will start on the obd1 conversion with a jumper harness. In theory i can get the car to run if i just bolt up the obd1 distributor and ecu. With out hooking up anything else, to just test my dpfi to mpfi conversion if i did it correctly. I should be only throwing a code 1 o2 sensor not found. Right? With the jumper harness installed. I can always crome a new ecu chop for my obd1 setup to run with out the o2 sensor if it's not present not throwing any codes. Untill i get a o2 sensor for the obd1 conversion/setup.
Modified by dem0nk1d at 1:57 PM 8/8/2007
Old Aug 8, 2007 | 10:08 AM
dem0nk1d's Avatar
bump
Old Aug 8, 2007 | 12:57 PM
dem0nk1d's Avatar
well i think i am correct. i guess this question is over the top or somethinG.
Old Aug 8, 2007 | 01:12 PM
Boosted Chemist's Avatar
Default Re: (dem0nk1d)
why not just use the obd0 02 and disable o2 heater in crome?
Old Aug 8, 2007 | 01:24 PM
dem0nk1d's Avatar
that's what i was thinking of doing untill i get the new o2. but i am saying once i am done doing the DPFI (2 injectors) to MPFI (4 injector) conversion. I will have bolted up 1 obd1 intake manifold, one obd1 dx ecu, and my sohc obd1 distributor. If i just plug in the conversion harness it should be only throwing the o2 code.
i think the only wires that lead out into the engine bay are, knock, vtec, o2, and something else not really need...
Old Aug 8, 2007 | 02:01 PM
You dont need knock and vtec unless you have a vtec head (obviously) Also u need an obd1 dissy. Obd0 has 16 pick ups and obd1 has 24 or something like that
Old Aug 8, 2007 | 02:17 PM
dem0nk1d's Avatar
i already have all my parts.
obd1 dx dist
obd1 intake manifold, rail, injectors
i got all the parts from my wrecked EG.
Faya
Engine Management and Tuning
Feb 16, 2009 07:40 PM
Swipe'd
Feb 14, 2008 03:34 PM
Ls On StErIoDs
Sep 12, 2005 09:04 PM
mrx
Mar 12, 2005 01:06 PM
h46it
Jun 18, 2002 05:23 PM
