CEL HELP!!!!
Old Aug 7, 2007 | 04:47 PM
Ha Itz's Avatar
Default CEL HELP!!!!
i have a 97 civic dx 5 speed with a 98 ls motor.. here is my problem i have a cel... i know that i should be throwing a code for the 02 sensor because i only have one hooked up... heres what im confused on i went to autozone and let them run a cel test and heres what came back Automatic transaxle FI signal A circuit failur ( thats what shows up exactly on the slip they printed out. There probable causes say Poor electrical connection or failed module... im completely lost and need some help.. why am i not throwing a code for the 02 sensor and what the hell is this automatic transaxle... and im running the proper ecu p75
Old Aug 7, 2007 | 08:11 PM
JimBlake's Avatar
Default Re: CEL HELP!!!! (Ha Itz a Jew)
Sometimes the text explanation is jacked up. You need to tell us the actual code number. Starting with "P" followed by 4 digits.
Old Aug 8, 2007 | 01:25 PM
Ha Itz's Avatar
Default Re: CEL HELP!!!! (JimBlake)
p1600
Old Aug 8, 2007 | 02:09 PM
Relic1's Avatar
if you're throwing an auto trans solinoid fault on a manual car... you have the wrong ECU.
what are the numbers on the side of the ECU?
P75-???
Old Aug 8, 2007 | 02:46 PM
Ha Itz's Avatar
Default Re: (Relic1)
yes its a p75... and the code is p1660 sorry.. its strange because before i was throwing just a o2 sensor code and now its no 02 sensor code and its just the p1660
Old Aug 8, 2007 | 03:03 PM
Relic1's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Relic1 &raquo;</TD></TR><TR><TD CLASS="quote">what are the numbers on the side of the ECU?
P75-???</TD></TR></TABLE>
those three numbers are what can tell me and you if it's an auto trans or not.
37820-P75-_ _ _
Old Aug 8, 2007 | 03:19 PM
JimBlake's Avatar
Default Re: (Ha Itz a Jew)
P1660 A/T-FI Data Line Failure/TCM - ECM Halt
That error code only makes sense coming from an auto-tranny ECU.
Old Aug 8, 2007 | 04:52 PM
Ha Itz's Avatar
Default Re: (JimBlake)
the ecu says its a 37820-p75-a52
Old Aug 8, 2007 | 05:29 PM
Dogginator's Avatar
Daisy... Daisy...
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Ha Itz a Jew &raquo;</TD></TR><TR><TD CLASS="quote">the ecu says its a 37820-p75-a52</TD></TR></TABLE>
That is from a '96 Integra B18B with an automatic transmission.
http://www.sonsacuraparts.com/...dIrno=
Old Aug 9, 2007 | 07:30 AM
Relic1's Avatar
Dogginator hit the nail right on the head.
37820-P75-_ _ _
A01 - 94-95 manual
A02 - 96 manaul
A03 - 97 manual
A04 - 98-99 manual
A05 - 00-01 manual
A51 - 94-95 auto
A52 - 96 auto
A53 - 97 auto
A54 - 98-99 auto
*** - 00-01 auto
jetblack
May 16, 2006 06:20 PM
arw321
Jan 22, 2004 08:33 AM
1.8Tities
Sep 9, 2003 02:11 PM
thefordmccord
Apr 3, 2002 04:02 PM
delsol93
Jun 21, 2001 02:54 PM
