help me identify this crank, b16b or b18c5
A guy has this crank for sale and swears it came from a ITR motor. Somehow I think it is a CTR crank because use to own a CTR, which he stroked. If it isn't neither please tell me what it came from.
here is a pic of my old ITR during a race meet. It ran consistant 13.7-13.8 all day.
you can tell by the counterweights.
the crank in this pic with assembly lube on it is a b16 (i know because i put it in my all motor build and found out the stroke was way short0 and the scratched up one is an ls (i know because it was in the motor my buddy blew up)
maybe that will help a tad? i would still measure tho to be 100% sure.
It still could be a CTR b16b crank. The ctr's had full counterweights, smaller width bearings, and the extra size numberings just like the itr cranks did. Measure the stroke to be sure. Measure the distance from rod journal centerline to main centerline and then double that number gives you stroke.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by pomansouth01 »</TD></TR><TR><TD CLASS="quote">looks like you did a 4 lug conversion on that type r...</TD></TR></TABLE>
It's a rhd 95-97 itr
if you even knew wtf im talking about you wouldnt doubt me... the itr crank can be discerned in plain view... from a ctr crank... i'll take pics of both tomorrow and show you then...
god its like telling children..
to even tell you a hint its not even the counterweights...
god its like telling children.. to even tell you a hint its not even the counterweights...
I know this will be hard to do, but as you do not have mearsuring devices you can try it. Install the crank with 1 and 5 bearings and caps. Put it at TDC (bearing throw at the top) set the rod and piston (no rings, but a bearing shell) into the cylinder if it sticks way the hell out of the block it is a b18 crank. If the deck is correct, guess what, you are OK. By the way "deck" means the piston flat part to the block surface "flat part" did not mean to get too technical.
Circuit Star-29
Feb 23, 2006 07:42 PM
FakeJDMEF8
Sep 14, 2004 09:25 PM
