b17 tranny question
Old Aug 7, 2007 | 04:15 PM
89hatcher's Avatar
Default b17 tranny question
just wondering how can you tell if you have a b17 gsr tranny??
Old Aug 7, 2007 | 04:29 PM
Colin's Avatar
Default Re: b17 tranny question (89hatcher)
It will say "YS1" on the sticker on the case... unfortunately ALL 92-93 manual transmission integras came equipped with "YS1" transmissions. So the only ways to know if you have the gsr version is to either pull it apart and count the teeth on the gears or install it and drive it.
Old Aug 7, 2007 | 04:43 PM
Crx Jimmy's Avatar
open it up it should have a 4.4 final
Old Aug 7, 2007 | 05:15 PM
Colin's Avatar
Default Re: b17 tranny question (Crx Jimmy)
ALL YS1's have a 4.4, even the taller geared LS versions....
Old Aug 7, 2007 | 06:18 PM
89hatcher's Avatar
so best bet would be to open it up and count the teeth or to install it and drive it.
Old Aug 7, 2007 | 06:25 PM
VtecSyndrome's Avatar
Default Re: (89hatcher)
there should be a way to turn the diff w/o taking anything apart and find out what it is by where the diff pin lines up with a marking on the case after a complete rotation.......or something close to that. gotta check with an experienced trans tech, I know there on here. maybe one will chime in soon or search for trans specs ir transmission identification. you'll probably see a few post of what I'm talking about.
Old Aug 7, 2007 | 06:53 PM
89hatcher's Avatar
Default Re: (VtecSyndrome)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by VtecSyndrome &raquo;</TD></TR><TR><TD CLASS="quote">there should be a way to turn the diff w/o taking anything apart and find out what it is by where the diff pin lines up with a marking on the case after a complete rotation.......or something close to that. gotta check with an experienced trans tech, I know there on here. maybe one will chime in soon or search for trans specs ir transmission identification. you'll probably see a few post of what I'm talking about.</TD></TR></TABLE>
i think its only been done with sohc trans..
Old Aug 7, 2007 | 06:59 PM
garageEF's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by 89hatcher &raquo;</TD></TR><TR><TD CLASS="quote">
i think its only been done with sohc trans..</TD></TR></TABLE>
x2....the only way to tell is to drive it or count teeth
Old Aug 7, 2007 | 08:49 PM
Mista Bone's Avatar
D Tranny Guru
Default Re: b17 tranny question (Colin)
sorry, LS YS1's have 4.26 FD's........
Old Aug 7, 2007 | 11:11 PM
Hamstr323's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Colin &raquo;</TD></TR><TR><TD CLASS="quote">ALL YS1's have a 4.4, even the taller geared LS versions....</TD></TR></TABLE>
SORRY BUT THIS IS INCORRECT THE LS'S HAVE A 4.26 AND THE GSR HAD A 4.4
EDIT** didn't see mr bones post
Old Aug 7, 2007 | 11:34 PM
Colin's Avatar
Default Re: b17 tranny question (Hamstr323)
since when has the LS ys1 had a 4.26? I've NEVER seen that posted anywhere.
Edit, I just did some searches to try and post links..... and now I've getting conflicting info. Until today I had never seen anyone say that the ls ys1 is a 4.26. I knew the y1 is a 4.26, but not the ys1. I still want some proof to which is actually the truth. And no, I'm not looking to prove myself right, I'd honestly like the correct info, either way.
http://www.allmotorhonda.com/t...s.htm
http://www.ff-squad.com/tech/temp/Bgears.htm
http://hondaswap.com/swap-arti...29099/
http://www.fatboyraceworks.com/gears/
http://www.knology.net/~jedikl...s.htm
And I'm sure there are more...... This is strange to me that I never saw this before, I guess I've been out of the scene too long. I'm gonna contact my tranny guru.
Old Aug 7, 2007 | 11:53 PM
89hatcher's Avatar
anyone figure out how to check it without opening it. by just spinning the spline
Old Aug 8, 2007 | 12:23 AM
Mista Bone's Avatar
D Tranny Guru
LS 90-91 small spline have 4.400 FD, 92-93 large spline have the 4.266 FD.
Helps that I work on SCCA ITA trannys, like 90-93 Tegs.
Old Aug 8, 2007 | 02:06 AM
JUN-DA6's Avatar
On B17 tranny driving 70mph will be about 4000 rpm.
Old Aug 8, 2007 | 06:20 AM
mahatma's Avatar
Default Re: (JUN-DA6)
what a bunch of bullshit. with all those serial #'s and potential casting spots, honda just couldn't be bothered to put a definitive identity on each different transmission...??!?!?
i thought counting splines & rotations was ridiculous, but having to crack open or install a transmission just to identify it?? bullshit.
Old Aug 8, 2007 | 10:02 AM
IT GUY's Avatar
Default Re: (mahatma)
https://honda-tech.com/zerothread/1967953
great thread on identifying transmissions
^^^D series.. sorry
the guy knows his stuff though
http://bensebuilt.livejournal.com/2006/01/08/
Richarddd
Transmission & Drivetrain
May 6, 2013 06:02 PM
gnccracer20
Jan 8, 2009 05:36 AM
Gong Show
13
Jul 15, 2007 08:38 PM
jay-tec
Nov 26, 2004 07:05 PM
integrabois1991
Aug 16, 2004 05:54 PM
