Here we go guys special on Injectors
55lb~577.5cc injectors for 280 shipped
72lb~756cc injectors for 350 shipped
96lb~1008cc injectors for 430 shipped
also have the high impedance injectors
50lb, 42lb, 38lb, 36lb, 30lb and 24lb
prices vary on thsoe models should be under 300 bucks shipped on most.
I have a built B18 motor, I will be getting hondata pretty soon, which injectors should I get I will be boostin 20psi real soon. Don't you have the RC injectors as well.
HOok me up I have money!
I'm assuming these are Peak and Hold?
Watcha got for me Viren.....
You need dual 1600cc for your methanol setup. you need to tap the JG lower portion on the intake manifold run -12 inlet and -10 return two weldon pumps or two aermotive prosereis pumps.
the quality is == as good. I use the bosch as well as msd both have never failed. on the other hand the venom injectors have failed many times.. never use those...
