Oil in Intake Manifold
Old Aug 7, 2007 | 03:42 PM
b16a4's Avatar
Default Oil in Intake Manifold
Today i took off my throttle body to adjust my TPS....
When i looked inside my intake manifold, i see oil.
What is the cause of that?
Old Aug 7, 2007 | 04:32 PM
doood's Avatar
been there done that
Default Re: Oil in Intake Manifold (b16a4)
that line running from the valve cover to the intake arm
Old Aug 7, 2007 | 05:51 PM
non-VTEC's Avatar
Default Re: Oil in Intake Manifold (doood)
.......and the PVC valve
Old Aug 7, 2007 | 06:11 PM
slowcivic2k's Avatar
Default Re: Oil in Intake Manifold (non-VTEC)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by non-VTEC &raquo;</TD></TR><TR><TD CLASS="quote">.......and the PVC valve</TD></TR></TABLE>
x2, a clogged PCV valve will end up forcing oil vapor into the throttle plate and manifold through the vent line in the intake arm.
Old Aug 7, 2007 | 06:15 PM
4g hatch's Avatar
Default Re: Oil in Intake Manifold (slowcivic2k)
also bad rings will cause your pvc to suck oil up,but i may be wrong
Old Aug 7, 2007 | 06:18 PM
Default Re: Oil in Intake Manifold (4g hatch)
Bad rings allow oil to enter the chamber, not the PCV.
Old Aug 7, 2007 | 08:17 PM
JimBlake's Avatar
Bad compression rings can allow more blowby, which can overwhelm the PCV system. Especially if the PCV valve is also marginal.
Parada
Feb 28, 2007 09:53 AM
thomas188
Oct 7, 2006 05:28 PM
bootlegtrader
Sep 19, 2005 11:46 AM
user 98292739
Apr 27, 2005 01:26 PM
