what oil can i use for my k&n air filter?
Old Jun 11, 2002 | 07:19 PM
itr501's Avatar
Default what oil can i use for my k&n air filter?
I know K&N makes a special oil for this, but is there any substitute I can use?
Old Jun 11, 2002 | 07:22 PM
DC2#428's Avatar
Default Re: what oil can i use for my k&n air filter? (itr501)
to be on the safe side i would stick to what K&N recommends otherwise the stuff you could be using could damage the material of the filter.
Old Jun 11, 2002 | 07:30 PM
TakaIntegra's Avatar
Default Re: what oil can i use for my k&n air filter? (DC2#428)
I read somewher that K&N oil is mineral oil mixed with red dye.
The cleaner is just laundry detergeant and water!
Old Jun 11, 2002 | 07:37 PM
itr501's Avatar
Default Re: what oil can i use for my k&n air filter? (TakaIntegra)
The reason behind my question is that I'm taking out and using my RU3130,which has been in storage for a few months. It still has a purplish color to it(not too dirty), but it does look a bit dry. Can the oil evaporate like that? I wrapped it in a plastic bag before storing it.
Old Jun 11, 2002 | 09:22 PM
DC2#428's Avatar
no it should be fine! If its still has that red colour on the filter and not white or brownish tint on the majority of the filter then it should be good!
Old Jun 11, 2002 | 09:25 PM
frogsr's Avatar
it's only about $10-15 anyways for the proper k&n cleaner and oil. not bad if you ask me. just make sure you don't over-oil the filter! i did, and it was drippy and left small drip marks eveywhere i parked for two days.
Old Jun 11, 2002 | 10:16 PM
ITR#132's Avatar
You can try ATF, even cheaper for a whole quart.
mvang001
Aug 21, 2011 06:35 PM
Adankid
Jan 1, 2009 03:12 PM
b18 hatch mike
Apr 24, 2008 08:32 PM
trianglegreg
Nov 19, 2005 12:54 PM
Nameless RB26
Jan 5, 2003 12:49 AM
