Does front lower H brace bar really help a lot in handling/coring?
it is for a eg hatch?
and does the rear lower bar helps a lot too?
thanks...
thanks...
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by crazyguy »</TD></TR><TR><TD CLASS="quote">Does front lower H brace bar really help a lot in handling/coring?
no not really, if you want alittle stiffness in the front, honda has a oem one. you can get them off any integra or del sol at the junk yard. this what they look like:
http://www.acuraoemparts.com/d...ch=no
item number 5.
if you want performance, your best bet would be to get a sway bar.
thanks...</TD></TR></TABLE>
the rear helps if it's a support brace for a sway bar, not only will it help in stiffness, but help prevent tear outs, which are quite common in eg's when upgrading the rear sway bar.
item number 5.
I like my setup. Separately, they don't stand out much, but together, they make a positive difference in crisper handling that I definitely noticed.
My setup:
NRG (yeah, on a budget)
-front tower bar
-front lower H brace
-rear tower bar
-rear lower tie bar
It's worth it to get the setup, but don't expect much from any of them separately. The setup, I've heard, also really benefits from front/rear sway bars, but I think any car will benefit from front/rear sway bars anyway.
My setup:
-front tower bar
-rear tower bar
-rear lower tie bar
The front lower H brace will help some but won't really be noticeable inless your like me and tend to push your cars limits in cornering.
