EG Rust in wheel well
Old Aug 7, 2007 | 11:59 AM
95 honda8's Avatar
Default EG Rust in wheel well
If you have rust near the wheel well is it fix aboule by welding a new pice on there without it rusting agin
Old Aug 7, 2007 | 12:15 PM
hondafrk's Avatar
Default Re: EG Rust in wheel well (95 honda8)
Yes it is repairable, The easiest repair is to remove the metal and find a set of front fenders and cut out the same shape and profile area to match and have them trimmed and welded into place. They should not rust again as long as they are cleaned properly and you remove that damn little rubber trim piece that acts as a rust promoter in your wheel well
Old Aug 7, 2007 | 12:20 PM
95 honda8's Avatar
Default Re: EG Rust in wheel well (hondafrk)
u mean the rubber pice is what causes the rust?
Old Aug 7, 2007 | 12:22 PM
philosofy1's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by 95 honda8 &raquo;</TD></TR><TR><TD CLASS="quote">u mean the rubber pice is what causes the rust?</TD></TR></TABLE>
no, if the rubber piece is damaged, or the paint is damaged, then bare metal is exposed to the elements. making it easy for rust to move in.
Old Aug 7, 2007 | 12:26 PM
95 honda8's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by hondafrk &raquo;</TD></TR><TR><TD CLASS="quote">Yes it is repairable, The easiest repair is to remove the metal and find a set of front fenders and cut out the same shape and profile area to match and have them trimmed and welded into place. They should not rust again as long as they are cleaned properly and you remove that damn little rubber trim piece that acts as a rust promoter in your wheel well
</TD></TR></TABLE> will a JDM fender work?? and it the left side is rusting dose it have to be a lft fender or dose it matter?
Old Aug 7, 2007 | 06:57 PM
LostBoy04's Avatar
That rubber piece tends to catch dirt and stuff which stays wet and it starts rusting.
Old Aug 7, 2007 | 07:21 PM
eg_boi's Avatar
Default Re: EG Rust in wheel well (LostBoy04)
or u can just buy a rear quarter panel from rustrepair.com if u're talking about the back. just cut, weld, sand, primer
shaunk18
Nov 27, 2007 05:15 PM
andrey320
22
Mar 7, 2006 07:18 AM
SC-MK1
Feb 22, 2005 11:21 AM
blkgsr03
Jan 25, 2005 03:03 PM
Mag00n
Nov 30, 2004 12:41 PM
