HELP - 93 Accord EX Idle Problems at Start up and shut down- PLEASE HELP
Old Aug 7, 2007 | 11:28 AM
tgkaotic's Avatar
Default HELP - 93 Accord EX Idle Problems at Start up and shut down- PLEASE HELP
Hi all,
1st post please help??
I have a 93 honda accord Ex, on start up cold the engine starts fine 5 seconds in the idle drops almost to stall then revs up to 1500 and the normal 900 and then almost stalls again, it does this about three to 4 times then idle evens out.
Then while starting from a dead stop when the car goes into second gear (auto) it dies sound like a backfire or exhaust pipe hitting the bottom of the car, I let go of the gas and give it gas again and it goes away???
Last when I stop to park and put the car in park it searches for idle, it goes from 800 to 1700 rpms about 3 to 4 times then settles???
Any help is appreciated.
Thanks in advanvce,
Tommy
Confused honda owner.
Old Aug 7, 2007 | 03:00 PM
slomob18b's Avatar
Default Re: HELP - 93 Accord EX Idle Problems at Start up and shut down- PLEASE HELP (tgkaotic)
Clean out your iac valve, check/replace spark plugs.
Old Aug 7, 2007 | 03:53 PM
tgkaotic's Avatar
Default Re: HELP - 93 Accord EX Idle Problems at Start up and shut down- PLEASE HELP (slomob18b)
Thanks,
I have changed the plugs and I will try and clean ivac.
Any other suggestions?
Old Aug 7, 2007 | 04:24 PM
hondaccord's Avatar
also check the timing belt it might have jumped a tooth. do ytou lack any power, you might not notice that though.
Old Aug 7, 2007 | 04:52 PM
tgkaotic's Avatar
Default Re: HELP - 93 Accord EX Idle Problems at Start up and shut down- PLEASE HELP (hondaccord)
Thanks,
It has lost power but how would I check this?
I would have to pull the cover and all off?
Thanks again,
I really appreciate all suggestions.
Old Aug 8, 2007 | 04:09 AM
hondaccord's Avatar
yep you got to pull your cover off and the crank pulley. there is a good walk threw on the accord faq on the top of this page.
Treyschls
Dec 20, 2015 11:36 PM
jckbnmbl
Oct 2, 2012 04:00 PM
brandonaccord
Jul 31, 2009 07:06 PM
tgkaotic
Aug 21, 2007 03:38 AM
DXK Eg
Mar 5, 2005 04:33 PM
