00 d series NON vtec into eg.. searched
ok so all i have left to do on my swap is wire the dizzy (obd2 non vtec)
from what ive read the wiring is different than the vtec dizzy but i cant find the
diagram for the for it.. any help would be greatly appreciated
Eaisest thing to do is to get an OBD-1 dist. The wiring, as far as I know, isn't any different. The internals are slightly different, thats all. You should be able to simply depin the OBD2 connector/plug and repin for the OBD1. The OBD1 uses smaller "pins" on the two coil wires however. You can either file/grind down the ones you have no to make it fit or cut the pins off another dizzy and solder them on the OBD2 style.
actually an OBD1 dizzy wont work 100% ie. the mounting legs slightly differ compared to OBD2 dizzy muont legs. If you can get one leg to fit, you'll be good and you can just plug n' play to your OBD1 harness.
I believe you need to run an OBD1 non-vtec dizzy as well.....
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Katman »</TD></TR><TR><TD CLASS="quote">actually an OBD1 dizzy wont work 100% ie. the mounting legs slightly differ compared to OBD2 dizzy muont legs. If you can get one leg to fit, you'll be good and you can just plug n' play to your OBD1 harness.
I believe you need to run an OBD1 non-vtec dizzy as well.....</TD></TR></TABLE>
OBD1 non vtec has different housing only on the SOHC's. Internals are the same. OBD2 Y7 and Y8 share the same housing and all. Not 100% sure if the obd1 housing will bolt to obd2 head however. I think at least one leg would match.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Hybrid96EK »</TD></TR><TR><TD CLASS="quote">
OBD1 non vtec has different housing only on the SOHC's. Internals are the same. OBD2 Y7 and Y8 share the same housing and all. Not 100% sure if the obd1 housing will bolt to obd2 head however. I think at least one leg would match.</TD></TR></TABLE>
whatever
</TD></TR></TABLE>whatever
whatever</TD></TR></TABLE>
just sayin
we're all friends here
just sayin
fracas
Aug 14, 2013 10:36 AM
