d15b swap into a 96 dx??
Old Aug 7, 2007 | 08:10 AM
andyvaj's Avatar
Default d15b swap into a 96 dx??
i'm pretty sure plenty of you have done it, but have a few quick questions. first of all it is a direct plug and play right: just hook up the v-tec wire to the ecu? anyone have a diagram of the jdm p08 ecu pin-out? what about the 02 sensor? do i have to do a single wire 02 sensor or is it ok with the 4 wires? i have a obd2 to obd1 conversion harness already. using the jdm p08 ecu. well, if theres anything else i need to know before i do the swap let me know. thanks ahead of time.
Old Aug 7, 2007 | 08:54 AM
HAMOTORSPORTS's Avatar
you will have to extend a few wires, convert to 2 wire iacv, etc. but otherwise should be straight forward.
Old Aug 7, 2007 | 09:02 AM
andyvaj's Avatar
Default Re: d15b swap into a 96 dx?? (andyvaj)
what do you mean when you say 2 wire iacv? and can i still use the 4 wire 02 sensor on the p08 ecu? i heard i can't? thanks
Old Aug 7, 2007 | 11:24 AM
your car originally ran a 3 wire iacv, your d15b should be 2 wire. yes, the o2 sensors should operate just as original.
Old Aug 7, 2007 | 02:43 PM
andyvaj's Avatar
how will i convert to a 2 wire iavc? anyone know this? have any pics or info? thanks. oh yeah, and i can use the 4 wire 02 sensor with the p08 ecu? thanks
Old Aug 8, 2007 | 08:05 AM
andyvaj's Avatar
i just realize that the distrubiter plug on the d15b is different from the d16y7 plug also? do i have to get a harness or what do i have to do? thanks
Old Aug 10, 2007 | 03:59 PM
andyvaj's Avatar
anyone???
Old Aug 11, 2007 | 08:55 AM
change the plug on the distributor harness to match your obd2 engine harness.
on last page of this link you will find the distributor wire colors for a reference
http://www.boomslang.us/obd0_1.pdf
Old Aug 11, 2007 | 09:24 AM
andyvaj's Avatar
Thanks HAMOTORSPORTSUSA!!! you have been a lot of help.
Cornwhiskey
Apr 11, 2004 02:47 PM
dingusjt
Nov 13, 2003 10:18 AM
Dancing is Forbidden
Jul 8, 2003 06:53 PM
AdamITR
May 14, 2003 05:44 PM
