modifying an 88-91 HKS Sport Exhaust cat-back to fit an 88-91 CRX?
Old Aug 7, 2007 | 01:20 AM
SmobbinSi's Avatar
Default modifying an 88-91 HKS Sport Exhaust cat-back to fit an 88-91 CRX?
Has anyone done this? Which pipe needs to be modified? Tried searching but came up with nothing. Thanks in advance.
Old Aug 9, 2007 | 04:00 PM
SmobbinSi's Avatar
Default Re: modifying an 88-91 HKS Sport Exhaust cat-back to fit an 88-91 CRX? (SmobbinSi)
bumpity
Old Aug 9, 2007 | 04:01 PM
MarlonT42's Avatar
I would bolt it starting from the back and see what you need to change...
Old Aug 10, 2007 | 02:43 AM
horsekiller's Avatar
you'll need to shorten the b-pipe.
Old Aug 10, 2007 | 03:48 AM
abnaasefmb's Avatar
Default Re: (MarlonT42)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by MarlonT42 &raquo;</TD></TR><TR><TD CLASS="quote">I would bolt it starting from the back and see what you need to change...</TD></TR></TABLE>
cut, weld
Old Aug 10, 2007 | 04:22 AM
import2nr88's Avatar
I have done this on my car.
I shortened the Mid Pipe on my car right after the resonator. I think I ended up cutting close to 6.5" out and then welding back together.
I found the easy way to do it is to do as follows.
* remove old exhaust from cat on back.
* Hang HKS muffler.
* install mid pipe to the muffler/tail section loosely.
* Have a friend measure how far you need to remove by measuring how much longer the flange that bolts to the cat is than it is supposed to be.
* Then remove the mid pipe, and cut out that amount from anywhere in the straight section that the resonator is on.
*Reinstall Mid Pipe, and enjoy a great exhaust.
-Jon
Old Aug 10, 2007 | 05:20 PM
SmobbinSi's Avatar
Default Re: (import2nr88)
Jon,
Thanks for your help and advice- I had it done at a local muffler shop and it is nice to have an HKS again! Nice and quiet but definite HP bump, just like the one I had back in 91! I like how they have a darker (almost Greddy SP) coating, compared to the almost silver like I had before.
The tips didn't come out as straight as yours, but I'm still happy!
Modified by SmobbinSi at 7:05 PM 8/10/2007
Old Aug 12, 2007 | 07:51 PM
Your tips should line up just right, just move the hangers on the bottom over a little until it's centered. That is the same spot I cut and welded mine at as well.
Old Aug 12, 2007 | 08:06 PM
goforbroke's Avatar
MEAT PATTY
Damnit, I need to dig mine out the basement and put it back on.
Old Aug 6, 2008 | 06:01 PM
Rob.'s Avatar
Default Re: (goforbroke)
Best exhaust for ef's !
Old Aug 6, 2008 | 06:09 PM
Vinceg99's Avatar
Default Re: (Rob.)
Im debating on shortenting the HKS exhaust I have or just selling it. I will say it did look nice on the hatch and from the pics above DOES look good on the CRX but I am going to be going turbo and not sure if it will be big enough?
Todd00
13
Nov 11, 2015 06:18 PM
REDBARON
Texas -OK -LA (Sales)
Sep 29, 2010 11:56 AM
pandarex
Mar 23, 2006 08:43 PM
b16crx0062004
Sep 18, 2005 10:11 PM
crxsi8
Feb 26, 2005 09:40 AM
