D16Y8 Tranny question
Old Aug 6, 2007 | 11:32 PM
BigDeal's Avatar
Default D16Y8 Tranny question
here are the specs 1997 EX coupe D16Y8, I just purchased from original owner, 150k miles on orig clutch/everything...
Recently i've been hearing a louder and louder grinding coming from within my trans. Im guessing its either the pilot or throwout bearing. It also has been poping out of second at wierd times. none the less i called around and asked how much a rebuild would be and i was quoted anywhere from 500 to 1300. I guess synchros arent cheap... My question is what is the majority doing, are you guys throwing down the coin for the rebuild, replacing with a different trans... (B16-B18 if possible) or buying from a junker?
Any help would be greatly apreciated, Its a DD and will only be seeing some minor bolt-ons if that helps.. Well, untill i can afford the proper boost setup.
Old Aug 6, 2007 | 11:47 PM
Syndacate's Avatar
Default Re: D16Y8 Tranny question (BigDeal)
You can't use B series transmissions on that car, only a D will bolt up. So a B16 or B18 won't work.
If it's grinding and popping out you're probably looking at more than just the throwout bearing.
I would just get a new Y8, but take it down, crack it open, see if you can find out what's wrong.
Old Aug 6, 2007 | 11:56 PM
BigDeal's Avatar
Default Re: D16Y8 Tranny question (Syndacate)
ok thanks for the clearification on the b-series.
Just so i dont get taken to the cleaners whats the going rate for a Y8 used trans?
I'm thinking about just throwing another used/good condition one in there, then rebuilding the one i have now slowly (this is my dd) to mate to a longblock Y8 and slowly building a snail setup.
Old Aug 7, 2007 | 12:00 AM
Syndacate's Avatar
In good condition (no grinds 'n ****) a Y8 trans's going rate is 2-300.
Old Aug 7, 2007 | 12:01 AM
BigDeal's Avatar
awesome... would that be private part or from a pull a part? somehow that seems alot easier and less time consuming then the rebuild route.
Old Aug 7, 2007 | 12:06 AM
Syndacate's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by BigDeal &raquo;</TD></TR><TR><TD CLASS="quote">awesome... would that be private part or from a pull a part? somehow that seems alot easier and less time consuming then the rebuild route. </TD></TR></TABLE>
That'd be from a scrapyard or private sale.
http://www.car-parts.com - check it out.
It's easier IMO. My Y8 trans is bad too, haven't been driving my EX in a few weeks. Gotta get a trans for it, mine is doing the same thing (grinding in every gear, even in neutral), it's probably just a bad input shaft bearing, but it's been grinding horribly for like 1.5k+ miles so chances are there's broken pieces all over the inside of the trans. So I'ma pick another one up whenever I get the hell around to it and throw it in. They're not hard to replace, and if you can't do it, a shop can do it for like &lt;$150 labor.
Old Aug 7, 2007 | 12:29 AM
BigDeal's Avatar
Thanks i'll give that site a try.
Im ok on the swap, I've done a few in my day. but when it comes down to rebuilding a trans i get completely lost. I just hope this one will last untill i get a new one or my butt is catching a bus. hehe. well bro thanks for all the help. Good luck on your situation.
Old Aug 7, 2007 | 12:38 AM
Syndacate's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by BigDeal &raquo;</TD></TR><TR><TD CLASS="quote">Thanks i'll give that site a try.
Im ok on the swap, I've done a few in my day. but when it comes down to rebuilding a trans i get completely lost. I just hope this one will last untill i get a new one or my butt is catching a bus. hehe. well bro thanks for all the help. Good luck on your situation.</TD></TR></TABLE>
Ha, thx, yeah, they usually last some time before they blow out, don't worry .
Old Aug 7, 2007 | 11:17 AM
BigDeal's Avatar
lol, worst case scenerio i'll be shifting from 1st to 3rd from now on. hehe.
Old Aug 7, 2007 | 02:40 PM
Budget Racer's Avatar
Try Craigslist.com and select your state and city/ auto parts.
or local classifieds, and duh Honda-tech Marketplace
Old Aug 7, 2007 | 02:48 PM
Syndacate's Avatar
Default Re: D16Y8 Tranny question (Budget Racer)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Budget Racer &raquo;</TD></TR><TR><TD CLASS="quote">Try Craigslist.com and select your state and city/ auto parts.
or local classifieds, and duh Honda-tech Marketplace</TD></TR></TABLE>
That's almost a good place to start - H-T market place is, but as for craigslist, most of the deals as far as trans goes are kinda fishy .
Old Aug 8, 2007 | 12:40 AM
Mista Bone's Avatar
D Tranny Guru
ISB dieing and CS bearing walkout, typical SOHC tranny.
Good used Y8 goes for $300 from private seller, $400 from a junkyard that knows their Hondas.
morganm58
Mar 3, 2011 07:12 PM
[HID]Sohc_Life
Mar 12, 2007 06:25 PM
NGUSPEED
17
Oct 2, 2005 06:38 PM
HksHaitian
May 3, 2005 07:03 PM
