car handles terrible...HELP
Old Aug 6, 2007 | 09:11 PM
bb4 jdm lude's Avatar
Default car handles terrible...HELP
i have a 4th gen p-relude that i hit on the passenger side front fender about 2 years ago, i have had it aligned but then i had rims and tires put on...i need new tyrod ends but other than that i cant think of what is wrong with it. can someone HELP me please
Old Aug 6, 2007 | 09:18 PM
M2B4's Avatar
Default Re: car handles terrible...HELP (bb4 jdm lude)
a better description? what does it do when does it do it?
Old Aug 6, 2007 | 09:21 PM
Default Re: car handles terrible...HELP (M2B4)
pulls very badly to the right and and in a turn the wheel is loose and twitchy acting
Old Aug 6, 2007 | 09:23 PM
snobordboy's Avatar
Moderator
If you need tie rod ends it means your steering rack can't control the wheels right, and could break and lose one side totally, so do yourself a favor, buy some tie rod ends for 35 bucks online, put them on and get aligned again.
Old Aug 6, 2007 | 09:25 PM
Default Re: car handles terrible...HELP (snobordboi)
also i have lowering springs on it and the body roll is terrible on it... im thinking all that is wrong with it is the tie rod ends but i am not sure
Old Aug 7, 2007 | 04:26 AM
bluedlude's Avatar
well theres no doubt you need to get those fixed. what if your driving down the road, or on the freeway, and it finally give out totally and sends you off the road? for something you could have fixed for under $100? also take a look at your radius rod and subframe. could be bent as well and causing it to pull. or it could be as easy as getting an alignment. go take a peak
snatch
12
Jan 25, 2008 11:36 AM
busyychild
Jan 3, 2008 01:30 PM
JDM_Andrew
Feb 22, 2007 09:54 AM
teletekman
Feb 24, 2006 09:10 AM
alleyezonme
Suspension & Brakes
Aug 9, 2005 05:09 PM
