EJ6 wont shift out of park, brake lights no longer work, wtf?
Old Aug 6, 2007 | 08:52 PM
DC5_lov3r's Avatar
Default EJ6 wont shift out of park, brake lights no longer work, wtf?
My car is an auto and it won't shift from PARK to REVERSE or DRIVE. I have to shift lock it from PARK to NUETRAL to start it. Now my brake lights don't come on when I brake.
Anybody know what's up with this? It's too late to look at anything, but I was told to check the fuse, maybe it went out. But it's strange now, after I remove my spoiler.
Old Aug 6, 2007 | 08:59 PM
n1_egsex's Avatar
* B A N N E D *
Default Re: EJ6 wont shift out of park, brake lights no longer work, wtf? (DC5_lov3r)
check the brake switch
Old Aug 6, 2007 | 09:01 PM
gourley's Avatar
Its your brake switch on your brake pedal.
#14 I believe
http://www.hondaautomotivepart...PEDAL
Old Aug 6, 2007 | 09:03 PM
DC5_lov3r's Avatar
Default Re: EJ6 wont shift out of park, brake lights no longer work, wtf? (duheeat)
Would this also cause the car not to shift gears from park to etc.?
Old Aug 6, 2007 | 09:19 PM
gourley's Avatar
The switch tells your car that you have the brake engaged enough so the car can be take out of park and be driven. If your switch is bad or broken, your lights wont come on and you wont be able to take your car out of park.
Just go to your local junkyard, you'll find one.
Old Aug 6, 2007 | 10:06 PM
93stockej1's Avatar
try to honk your horn. if your horn doesnt work then its ur under hood fuse. i had the same problem. i think its a 20a fuse or somethin
Old Aug 6, 2007 | 11:07 PM
sageuvagony's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by DC5_lov3r &raquo;</TD></TR><TR><TD CLASS="quote">Would this also cause the car not to shift gears from park to etc.?</TD></TR></TABLE>
yes
Old Aug 6, 2007 | 11:09 PM
Essenar83's Avatar
Your car's transforming into 5-speed.
Old Aug 7, 2007 | 06:23 AM
DC5_lov3r's Avatar
Default Re: EJ6 wont shift out of park, brake lights no longer work, wtf? (93stockej1)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by 93stockej1 &raquo;</TD></TR><TR><TD CLASS="quote">try to honk your horn. if your horn doesnt work then its ur under hood fuse. i had the same problem. i think its a 20a fuse or somethin </TD></TR></TABLE>
Yeah, the horn doesn't honk.
Old Aug 7, 2007 | 06:29 AM
electron_si's Avatar
Yeah, the horn doesn't honk. </TD></TR></TABLE>
wow looks like you found the problem
Old Aug 7, 2007 | 06:34 AM
DC5_lov3r's Avatar
Default Re: EJ6 wont shift out of park, brake lights no longer work, wtf? (electron_si)
Thanks for your sarcasm, it's gonna help me right now.
Old Aug 7, 2007 | 12:12 PM
DC5_lov3r's Avatar
Ok, well I changed the fuses, even though they look good. Horn works now, but the tail lights don't.
Change the brake switch, still don't work.
Any more help? Car still won't leave park, still have to shift lock to nuetral to start it.
I'm completely lost, maybe a shortage somewhere? I dunno.
Old Aug 7, 2007 | 12:26 PM
DC5_lov3r's Avatar
I found this:
http://wiki.answers.com/Q/How_...pedal
Will that also work for a 96 DX?
Old Aug 7, 2007 | 12:43 PM
philosofy1's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by DC5_lov3r &raquo;</TD></TR><TR><TD CLASS="quote">I found this:
Will that also work for a 96 DX?</TD></TR></TABLE>
it's basically telling you how to trouble shoot the brake wiring. which that is what you will have to do if you want to fix the problem. the indication of a blown fuse means most likely you have a short.
you said this started after you removed your spoiler. i would back track and double check all wires. make sure none got torn, pinched, or exposed to metal. also make sure no water got into where the wire are, it will also cause it to short out if wires are exposed or water got into the harness.
Old Aug 7, 2007 | 01:24 PM
DC5_lov3r's Avatar
Default Re: EJ6 wont shift out of park, brake lights no longer work, wtf? (philosofy1)
Well, i was about too remove the panels and check it. But I decided to take one more look at the fuses, and bam! They work. I don't know, guess it was the fuses but they're working now.
Thanks for the input guys, H-T'ers.
l Anito
Honda CR-V & Element
Dec 21, 2011 10:46 AM
tabartis
Dec 21, 2011 09:52 AM
krisfnbs
Mar 16, 2011 01:29 PM
vitalove00
Acura TL, RL & ZDX
Sep 30, 2008 05:57 PM
bard
13
Mar 22, 2007 02:34 AM
