4.7 Final Drive for H2B setup - Yes or No
Old Aug 6, 2007 | 08:02 PM
2fastGSR's Avatar
King of the One Liners
Default 4.7 Final Drive for H2B setup - Yes or No
I have seen everyone pretty much staying with the stock 4.4 and doing well but my question is down the road do you think eventually something like a 4.7 would be better?
Basically im building my H2b setup now and just wondering while the trans is already apart if i should just throw one in there. To start the motor will just have bolt ons and 22 inch slicks @ track. But this winter will be a nice big, high cr motor so again im just wondering if i should throw it in now while im putting in the lsd.
Any thoughts?
Old Aug 6, 2007 | 08:07 PM
2fast4u831's Avatar
I'm really 2slow
Default Re: 4.7 Final Drive for H2B setup - Yes or No (2fastGSR)
I would only go with a 4.7fd is I was building something with high compression and mostly for track. bigger final drive also means bigger tires which results in a bigger contact patch you will probably be at around 4.5k rpms on the freeway.
Old Aug 6, 2007 | 08:11 PM
2fastGSR's Avatar
Default Re: 4.7 Final Drive for H2B setup - Yes or No (2fast4u831)
well i was definitely going to step the slick size up next year with the bigger motor, but i just didnt want the 4.7 to be basically "overkill" for now, which is what it seems like you're saying it might be.
thanks . i appreciate the input
Old Aug 7, 2007 | 05:47 AM
Bense's Avatar
What trans are you starting out with? GSR or B16/ITR trans?
Old Aug 7, 2007 | 02:38 PM
Richard...'s Avatar
Default Re:
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by 2fast4u831 &raquo;</TD></TR><TR><TD CLASS="quote">I would only go with a 4.7fd is I was building something with high compression and mostly for track. bigger final drive also means bigger tires which results in a bigger contact patch you will probably be at around 4.5k rpms on the freeway. </TD></TR></TABLE>
What a load of rubbish i hope this clears up all the miss information!
http://www.team-integra.net/fo...Topic
Gears effect were your land point are and what your driving on the freeway at not the bloody FD
Anyway read the link it is all explained their hope we can cap this miss information
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Bense &raquo;</TD></TR><TR><TD CLASS="quote">What trans are you starting out with? GSR or B16/ITR trans?</TD></TR></TABLE>
i believe the b16 has the better "gearing" then the gsr right? If not that would be preferable!
Anyway in answer to your question about final drives if you read and FULLY understand the above link i have given you then you will understand when i tell you get at the least a 4.9 final drive and a 5:1 if you can afford it or bigger!
Old Aug 7, 2007 | 05:03 PM
2fastGSR's Avatar
Default Re: Re: (Richard...)
Yes, b16 trans .
Wow that link was a lot to take in and definetly taught me some stuff- i appreciate it man, thanks
Old Aug 7, 2007 | 05:09 PM
Bense's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Richard... &raquo;</TD></TR><TR><TD CLASS="quote">
I pwned that writeup
http://bensebuilt.livejournal.com/2006/01/08/
lol
nah i got sick of typing the same thing over and over and over so i created that writeup.
nah what you can do is go here and find out an estimated trap speed
http://www.stealth316.com/2-calc-hp-et-mph.htm
then if it's like 118mph, make your 4th gear end at like 120mph.
if you're revingto like 8100 you may want to just use a stock 4.4 b16/itr gearing.
if you're using gsr trans then i'd run the 4.7
just my $0.02
Old Aug 7, 2007 | 05:59 PM
88ED8's Avatar
ok, a '98+ JDM ITR has a 4.785 FD, most people think that will put your 5th gear cruising mph at a high rpm..... but in comparison to the USDM ITR 4.4FD transmission it's actually within a few mph.... You see, the jdm and usdm both have the same 1st, 2nd, and 3rd ratios but with the jdm having a 4.785 it makes gears 1-3 shorter than that of the usdm.... But on the other hand the jdm has a taller 4th and 5th gear than that of the usdm, combine a taller 4th & 5th with a 4.785 and you get something close enough to compare to a usdm tranny... I hope this makes sence to at least one person... but to make a long story short when comapreing a 4.4fd ITR with a 4.785fd ITR, basically 1-3 are shorter and 4th & 5th are within a few mph.. What ever you decide just keep the gears short and close as possible and gear it to finish the 1320 on the top of 4th
Old Aug 7, 2007 | 06:02 PM
88ED8's Avatar
Default Re: 4.7 Final Drive for H2B setup - Yes or No (88ED8)
and I wouldn't use 22's with a 4.7fd
Old Aug 7, 2007 | 06:56 PM
2fastGSR's Avatar
man..... im more confused then ever
I guess its going to just have to be one of those things i just try and see what happens. After all i am getting good at taking trannys in and out lol
Old Aug 7, 2007 | 08:49 PM
Bserious's Avatar
My 2 cents, FTW stick with the 4.4.
Old Aug 7, 2007 | 10:11 PM
88ED8's Avatar
pm'ed ya back, my advice, just leave it stock, put in a LSD and run 23's
Old Aug 9, 2007 | 08:46 PM
AllMotorRandy's Avatar
is this a daily driver?
Old Aug 10, 2007 | 06:25 AM
2fastGSR's Avatar
Default Re: 4.7 Final Drive for H2B setup - Yes or No (AllMotorRandy)
not really a daily. Ill drive it around a lot, but definitely not a dd.
Getting too old to deal with the damn vibrations of a modded honda
Old Aug 10, 2007 | 12:34 PM
skunked's Avatar
Default Re: 4.7 Final Drive for H2B setup - Yes or No (Bserious)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Bserious &raquo;</TD></TR><TR><TD CLASS="quote">My 2 cents, FTW stick with the 4.4. </TD></TR></TABLE>
Unless you need more slick I agree
Old Aug 10, 2007 | 06:02 PM
If your motor is stock with bolt on's..... I'm going to have to agree with the majority and say stick with the 4.4 tranny on 22" slicks.
Build the tranny around the motor when you get that CR monster in there. Shameless plug......"My MFactory 4.928 final drive really helped my ET's especially when you need bigger slicks".... Good Luck!!!
AH VTEC
Transmission & Drivetrain
Sep 14, 2009 12:54 PM
jt-sport
17
Jan 21, 2007 11:06 PM
turbodsmpower
12
Jun 1, 2003 01:37 PM
