Overbore ?
take it to a reputable shop which houses a cnc mill to accurately machine the sealing bores...theres tons of shops i live in canada there are only a few around the toronto area here...and im curious what bore size you planning on running anyway?? is this a full block build or just a slight overbore?? because you have piston and compression options now if you dont plan on building the motor dont bother sleeving i say...
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Jdmb16sir2 »</TD></TR><TR><TD CLASS="quote">Whats the biggest bore i can take a B17a to safely without sleeving it.</TD></TR></TABLE>
82mm. but that leaves no room for a rebuild.
brokeHonda
10
Oct 19, 2005 04:22 PM
