OEM USDM Foglights for 1990 hatchback
Old Aug 6, 2007 | 01:47 PM
Hondacivic90ed's Avatar
Default OEM USDM Foglights for 1990 hatchback
Does anyone know if there were different brackets for the 88-89 foglights and the 90-91 foglights? I have a foglight set that is brand new in box all parts are accounted for. The brackets that I have don't even start to line up. They look like they are for a different bumper beam than the one I have. I know that the front ends of the 88-89 and 90-91 are different but the fog light set I have is labeled for a 91 so I thought it would work fine. But now I have the holes and wiring all set and ready to accept the foglights and the brackets will not work. So I need to know if anyone knows if there are two different brackets, if someone has a picture of theirs installed on a 90 or 91 or even an 88 or 89 it would help me out. I want to have it all oem and clean and not have to fabricate something if I don't have to. The foglights are brand new and so is everything else so I want it to be right. Thanks in advance.
Old Aug 6, 2007 | 01:51 PM
wiZCo's Avatar
Stouts 'n' Scotch
Here's the 90-91 ones.
Here's where they mount on the support:
Old Aug 6, 2007 | 02:58 PM
thank god someone replied and it helps, would you happen to know what the part numbers are for those brackets? Thats what I thought I needed.
Old Aug 6, 2007 | 03:07 PM
wiZCo's Avatar
Stouts 'n' Scotch
Default Re: (Hondacivic90ed)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Hondacivic90ed &raquo;</TD></TR><TR><TD CLASS="quote">thank god someone replied and it helps, would you happen to know what the part numbers are for those brackets? Thats what I thought I needed.</TD></TR></TABLE>
Even if I did, you wouldn't be able to get them from Honda anymore.
Got your PM, replied.
Old Aug 6, 2007 | 03:14 PM
Crx Jimmy's Avatar
Default Re: (wiZCo)
I think for some strange reason the brackets are available although the lights are not
Old Aug 6, 2007 | 03:15 PM
Default Re: (wiZCo)
you are the man, i would have never thought I could have found them so fast, I thought I was screwwed. Thanks a lot man you have no idea.
Old Aug 6, 2007 | 03:18 PM
wiZCo's Avatar
Stouts 'n' Scotch
Default Re: (Crx Jimmy)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Crx Jimmy &raquo;</TD></TR><TR><TD CLASS="quote">I think for some strange reason the brackets are available although the lights are not</TD></TR></TABLE>
Already tried to get them a few years back, I'd forgotten that mine were still bolted to the bumper support upside-down.
They don't have 'em.
wali
May 26, 2010 07:31 PM
problem_si
Feb 5, 2008 10:55 AM
Chrisdotcom
13
Feb 16, 2007 01:16 PM
UsDm_Junky
15
Sep 19, 2005 02:58 PM
stealth civic
May 16, 2004 10:06 PM
