setting up dc5 for scca pro
Old Aug 6, 2007 | 01:41 PM
iskate2's Avatar
Default setting up dc5 for scca pro
hey everyone im well versed in b series, but a newbie to the k. This is also the first honda road race car ive been involved in, so youre helping two vintage porsche guys build a RSX.
anyways, im setting up an aim dash in a dc5 chassis, and Im in need of a proper port for the oil temp guage. also, where would i pull and return oil for a cooler? The engine is simply stamped k20a, so i assume it is a jdm version (red valve cover), probably a type r? pics would really help.
thanks,
matt
Old Aug 6, 2007 | 04:56 PM
eMpAtHy's Avatar
Default Re: setting up dc5 for scca pro (iskate2)
that is correct, the K20A is indeed the engine that comes standard on the type r.
Old Aug 6, 2007 | 07:16 PM
iskate2's Avatar
anyone else?
Old Aug 6, 2007 | 07:51 PM
typesnick's Avatar
Default Re: (iskate2)
to pull oil from the motor for an oil cooler you could get a T fitting off of where the vtec solenoid is screwed in to the head behind the heat shield on the back of the motor thats how the greddy turbo kit for a rsx gets its oil for the turbo then it runs down to the oil pan throught a fitting you could either tap a fitting in the oil pan or use a bandgo bolt like the use in the greddy kit to dump the oil back in to the pan but i would rather tap a hole and install a fitting into the pan and there is also a part you could get that screws on to where the oil filter goes and it has a fitting for the oil to come out of but idk about in but i think it does my buddy his 05 rsx has that but then again he is puttin 628 to the wheels on 28pounds of boost
Old Aug 7, 2007 | 12:23 PM
sander's Avatar
2.7(p/t)
Default Re: (typesnick)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by typesnick &raquo;</TD></TR><TR><TD CLASS="quote">to pull oil from the motor for an oil cooler you could get a T fitting off of where the vtec solenoid is screwed in to the head behind the heat shield on the back of the motor thats how the greddy turbo kit for a rsx gets its oil for the turbo then it runs down to the oil pan throught a fitting you could either tap a fitting in the oil pan or use a bandgo bolt like the use in the greddy kit to dump the oil back in to the pan but i would rather tap a hole and install a fitting into the pan and there is also a part you could get that screws on to where the oil filter goes and it has a fitting for the oil to come out of but idk about in but i think it does my buddy his 05 rsx has that but then again he is puttin 628 to the wheels on 28pounds of boost</TD></TR></TABLE>
NO. You must NOT use this. this is 1/8th BSPT, far far too small for an oil cooler feed.
If your planning on running an air based oil cooler, you must not use a line smaller than -8AN. Most of the popular oil coolers wont come with fittings smaller than that (Setrab, etc...) You can use a sandwich plate from the oil filter where the oil filter is.
If you want to get a reliable oil temp reading you should weld an aluminum bung for the temp sender in the lowest portion of the oil pan.
Old Aug 7, 2007 | 06:26 PM
iskate2's Avatar
thanks i figured out the oil temp- i came to the same conclusion about the oil pan. I also understand the idea about the -8 line for the cooler...this isnt my first race car, just the first honda race car. Any other points besides the oil filter sandwich plate? i can go that route if need be, but i just want to know my options. i wont actually see the car again until next friday...(8/17)
Old Aug 8, 2007 | 05:55 PM
iskate2's Avatar
anyone else have any tips before i let this thread go?
lsturbo*
30
Nov 25, 2019 07:44 AM
JDMBOY1904
Jun 15, 2009 12:01 PM
typesnick
Feb 14, 2008 02:22 PM
KF_S2000
Aug 13, 2003 12:07 PM
ThatDude
17
Feb 11, 2002 08:25 PM
